CME- Dail plan issue
anvelusa
having dialling issue in the CME system when dialling mobile number <90!>
looks like we have conflict of dial plan here. we need find the solution for the same.
Internal IP Phone directory number range:
9001-9099
PSTN Mobile Number pattern:
90!
problem here when we dial the mobile number if the first 4digits are matching with the internal number its directly routing the internal extension and not allowing us to dial the further number to reach the desired mobile numbers.
tried configuring < timeouts interdigit 3>, but no luck.
requesting you to have a look and propose solution for this issue..
adding CME config for reference:
dial-peer cor custom
name number.T
name number9.......
name number2.......
name number8.......
name number9999
name number1...
name number7.......
dial-peer cor list Intenational
member number.T
dial-peer cor list GSM
member number9.......
member number7.......
dial-peer cor list LandLine
member number2.......
dial-peer cor list TollFree
member number8.......
dial-peer cor list DirSer
member number1...
dial-peer cor list CallEmergency
member number9999
dial-peer cor list NormUsers
member number9999
member number1...
dial-peer cor list PrivUsers
member number.T
member number9999
member number1...
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
forward-digits 0
dial-peer voice 30 pots
corlist outgoing GSM
destination-pattern 9.......
port 0/0/0:15
forward-digits 8
dial-peer voice 31 pots
corlist outgoing LandLine
destination-pattern 2.......
port 0/0/0:15
forward-digits 8
dial-peer voice 32 pots
corlist outgoing TollFree
destination-pattern 8.......
port 0/0/0:15
forward-digits 8
dial-peer voice 34 pots
corlist outgoing CallEmergency
destination-pattern 9999
port 0/0/0:15
forward-digits 4
dial-peer voice 20 pots
trunkgroup INTERNATIONAL_FAC
corlist outgoing Intenational
destination-pattern .T
dial-peer voice 35 pots
corlist outgoing DirSer
destination-pattern 1...
port 0/0/0:15
forward-digits 4
dial-peer voice 36 pots
destination-pattern 7.......
port 0/0/0:15
forward-digits 8
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 110
max-dn 400
ip source-address <> port 2000
service phone displayIdleTimeout 08:00
service phone webAccess 0
system message <>
url authentication http://<>/CCMCIP/authenticate.asp
load 7945 SCCP45.9-2-1S
load 7965 SCCP45.9-2-1S
time-zone 35
date-format dd-mm-yy
voicemail 2222
max-conferences 8 gain -6
web admin system name <> password <>
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern ....
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 30 2018 17:56:35
Raghavendra G V
