How to determine direction of an on-going call
illachiranjeevi
Hello - I am struggling to find the direction of an on-going call, The scenarios is
1. Made a call from Terminal1's DN1 to Terminal2's DN2
2. Started my JTAPI application and added Observers for Terminal1& Terminal2
3. Receiving CallEvents and processing, but not setting Direction properly for call on Terminal2's DN2
JTAPI version: 6.1(2.1000)-12
CUCM: 9.1
Is there any sample application or doc that can direct me in right direction which can provide all the required information of on-going call like direction, current state(state i can get from events but). Tried on CiscoConnection#getReason, but this getting different results on different scenarios.For instance, after adding monitors, making an outbound call getting reason=99, but for the same call, if I add monitor on-going call getting reason=1
Basically I would like to Set the Correct State, direction and CLI on on-going calls
Best,
Chiru
May be I did not get the issue. Can you explain what you mean by direction of the call?
If user's phone is 600018, in this call where CallingAddress is 600018 and CalledAddress is 600019, user made the call. Only called parties can answer the call. From user (600018) perspective the call is an out bound call to called party (600019).
8 Replies 8
mpotluri
Level 5
Level 5
The state of the call can be determined by the state of the terminal connections for Terminal1 and terminal2.
callControlCall.getCallingAddress() and callControlCall.getCalledAddress() will give the calling and called parties (direction) of the call.
Thanks, will give it a try
Also, what would be right class or interface to fetch all call data mentioned like direction, state, caller & called parteis ? Will CallControlCall useful or do I need to query specific api for specific data ?
Hi mohan - I was not able to determin the direction of a call with callControlCall, am I missing something here. I am getting DN numbers on callingAddress & calledAddress. Like said I need to determine if user made an outbound call or answered an Incoming call. parsting out put of test scenario if this can be helpful to you to analyse
Made a call from 600018(on SEPB000B4D82DD8) to 600019, and answered on (SEPB000B4D82AB7)
Incoming:
Terminal Event: 1073745924 - CiscoTermOutOfServiceEv
Terminal Event: 1073745923 - CiscoTermInServiceEv
Address Event: 1073750018Address: null
CiscoAddrInServiceEv - Address: 600021
Address Event: 1073750019Address: null
CiscoAddrInServiceEv - Address: 600020
CallEvent: CallActiveEv callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: ConnCreatedEv callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: ConnConnectedEv callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: CallCtlConnEstablishedEv callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: TermConnCreatedEv SEPB000B4D82AB7 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
State of Call: 88
CallEvent: TermConnActiveEv SEPB000B4D82AB7 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: CallCtlTermConnTalkingEv SEPB000B4D82AB7 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
Address Event: 1073750018Address: [Ljavax.telephony.Connection;@794baafe
CiscoAddrInServiceEv - Address: 600019
Outgoing:
Incoming:
Outgoing:
CiscoAddrInServiceEv - Address: 600017
CiscoAddrInServiceEv - Address: 600018
CallEvent: TermConnCreatedEv SEPB000B4D82DD8 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
State of Call: 88
CallEvent: TermConnActiveEv SEPB000B4D82DD8 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
CallEvent: CallCtlTermConnTalkingEv SEPB000B4D82DD8 callControlCall#getCallingAddress: 600018 callControlCall#getCalledAddress: 600019
Thanks mohan, that helped, how ever yet to try on shared line scenario.
CallAlerting event & CallInitiated event will help u to get direction of the call.
Umesh
I am adding observers on an on-going calls, so CallAlerting & CallInitiated event wont be availble Umesh
