TCL: Check if DigitCollect is active on call leg
Hi all,
Can you please advise how i can verify if DigitCollect is already active on a call leg.
If ( DigitCollectLeg is not Active on leg)
# Issue DigitCollect on Leg
leg collectdigits leg_incoming PARAM
17 Replies 17
could you please collect the logs with debugs "debug voip app" .
Raghavendra
Hi İ collected debug and attached.
Thank you for your help
looks like you need to change the code in different place
if { $dest == "0" } {
                set dest $oprtr
                #handoff callappl leg_incoming default "DESTINATION=$dest"
                leg setup $dest callInfo leg_incoming
  } else {
                act_Select
Raghavendra
