08-06-2018 11:24 PM 08-09-2018 11:37 AM 更新
Hi all,
We have recently migrated few ISR G1s to ISR 4K and found that TCL script which was working previously with ISR G1 is now not working in ISR 4K. The script is being used for simple IVR (customized though).
Issue description: When IP Phone user makes a call to H.323 VGW (thr' CUCM) and the script is being invoked through inbound dial-peer, the caller gets dead air or TCL is not able to play .wav file.
Any further help would be really appreciated.
Attaching TCL script and few logs.
-Vivek
08-07-2018 03:57 AM
Hi Vivek,
which IOS version you are using ? can you share output of "show version" and logs with debug command.
"debug voip app"
Raghavendra
08-07-2018 05:36 AM 08-09-2018 11:38 AM 更新
Thanks Raghavendra.
Please find attached 'debug voip app' logs.
IOS-XE: 3.16.6S
- Vivek
08-07-2018 09:55 AM
can you try with latest 16.x version. I think there is bug for ISR G3 with tcl script.
below media files are not playing is that correct ? are you able to collect digits ?
media play leg_incoming flash://01.au flash://01.au flash://01.au
Raghavendra
08-07-2018 10:35 AM
Hi Raghavendra,
Yes, that's the welcome prompt (01.au) and digit collection is working good.
Checked with 16.6.2 and same result. Any specific version you would suggest?
- Vivek
08-07-2018 10:45 AM
08-07-2018 08:47 PM
Hi Vivek,
As yawming suggested try with different audio file and also add some silence between each file and try as below.
media play leg_incoming $source$header.au %s1 $source$header.au %s1 $source$header.au
Raghavendra
08-07-2018 09:27 PM
Checked with difference wav files from B-ACD (renamed it) and added silence as well, but same result.
- Vivek
08-08-2018 09:32 AM
So I guess cannot play any audio file with any Tcl script in ISR 4K ?
08-08-2018 10:35 AM
B-ACD (default TCL) is working fine on the same platform and IOS.
- Vivek
08-08-2018 10:39 AM 08-08-2018 12:40 PM 更新
Do you have any simple script to play your not working audio file to see if it works with other script ?
001049: *Aug 7 13:13:48.676: //5//MSM :/ms_associateDone: First Buf Play at 00:02:59.155 of 01.au
001050: *Aug 7 13:13:48.676: //5//MSM :/ms_associateDone: 00:02:59.155, Tstart(ply: iSndDly 0)
001051: *Aug 7 13:13:48.679: //5//MSM :/ms_handle_stream_timer: >>ms_start_play()
001052: *Aug 7 13:13:48.679: //5//MSM :/ms_start_play: 00:02:59.158, Tstart(ply: i_dly 4)
001053: *Aug 7 13:13:48.723: //5//MSM :/ms_cbf: (p 00:02:59.202 z)
001054: *Aug 7 13:13:48.723: //5//MSM :/ms_stop_play: mgdTstop at 00:02:59.202 (cause MS_STOP_COMPLETE)
001055: *Aug 7 13:13:48.723: //5//MSM :/ms_stop_play: Play Stopped at 00:02:59.202
Looks like file was played but start and stop immediately
08-08-2018 11:22 AM
Can you please try
media play 01.au
directly without "flash://"
01.au is a long file why need to play 3 times ?
06-03-2019 06:42 AM
Did find out whats happen ?
I'm with the same problem. The script work properly on 2900 router but when I try the same script on ISR 4000 I have a lot of problems.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
