Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi, I am using Cisco TSP (TAPI) on windows platform for CTI integration with Cisco platform. I am monitoring softphone (Cisco Unified Client Services Framework) via Cisco TSP (TAPI). This soft phone is linked with my end user who is using Cisco Jabbe...
Hello Everyone I have a problem about TCL IVR in my case gw does not play busy tone pstn callers. Do you have any ideas what causes the trouble? I have seen smilar case as follows. Call legs is return ls_007 I think some more parameters needs to be a...
KY_ by • Level 7
  • 14830 Views
  • 14 replies
I have a Cisco CME 10.5 with SPA 300 Telephones, all works fine, except the Moh. The music on hold does not work, when I leave a call in hold or transfer it, the music does not sound. I add the relevant config that I have, please help IOs: version 15...
jabe by • Frequent Visitor
  • 1354 Views
  • 2 replies
Hello,  what would be the easiest/proper way to detect incoming call on PC for given user?   Scenario: user has IP Phone and PC, when call is incoming I would like to detect that and display notification on PC. I can see there are multiple ways to in...
sigtrm by • Community Member
  • 1833 Views
  • 2 replies
Dear Cisco dev community,    I am working on a project whereby using the TAPI functionality, I am monitoring calls between several lines. All's currently well however, I am unable to monitor a line which was created on a third party SIP device.    Is...
pwrp4j1 by • Community Member
  • 2284 Views
  • 1 replies
My client has a office on a Serviced Building , there is a lease line and they have connected to that a CISCO, MODEL- ASA 5506, SN: JMX2201G04G And it's working fine. The network IP is 10.24.10.170 and problem is when I connect 2 IP phones, That have...
having dialling issue in the CME system when dialling mobile number <90!>   looks like we have conflict of dial plan here. we need find the solution for the same.   Internal IP Phone directory number range: 9001-9099   PSTN Mobile Number pattern:  90...
anvelusa by • Cisco Employee
  • 1721 Views
  • 1 replies
There is a guide from Cisco saying what phones are supported by TAPI https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/tapi_dev/12_0_1/CUCM_BK_C6F20193_00_tapi-developers-guide_1201/CUCM_BK_C6F20193_00_tapi-developers-guide_1201_appendix_01100...
anna.riley by • Community Member
  • 1888 Views
  • 2 replies
