Validate Wrong Extensions
Leonardo Santana
Hello
When dial a wrong extension the message you to reenter the destination did not play, and after a while the call is transfered to the operator.
Follow my script.
Extension Range: 9xxx
How can i do this?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
11 Replies 11
Raghavendra G V
Hi Leonardo,
You can use pattern for leg collectdigits as below if you want to match specific pattern.
set pattern(1) "9..."
leg collectdigits $legID params pattern
for more information refer TCL IVR document in below link.
https://developer.cisco.com/site/collaboration/call-control/voice-gateway/documentation/
Raghavendra
Hello Raghavendra,
Where do i put this commands?
At proc init ?
Leonardo Santana
Leonardo Santana
Hi Leonard,
you need to put pattern before leg collectdigits in act_Setup . you can also try to check the first digit after collecting all digits.
Raghavendra
Can you give an example im my script.
I tried but not work.
Leonardo Santana
Leonardo Santana
when you dial wrong extension, the script should get digit collect status cd_006. could you please collect logs by enabling below debugs.
debug voip app
Raghavendra
Hi Leonardo,
Per Raghavendra's suggestion- This is how he means on your script:
proc act_Setup { } {
    global param1
    global selectCnt
    global dest
    global beep
    global callInfo
    global dnis
    global fcnt
    global aaPilot
    global oprtr
    global busyPrompt
    global legConnected
    puts "proc act_Setup"
    set busyPrompt _dest_unreachable.au
    set beep 0
    init_perCallVars
    infotag set med_language 1
    if { ($dnis == "") || ($dnis == $aaPilot) } {
        leg proceeding leg_incoming
        leg connect leg_incoming
        set legConnected true
    puts "\nNo DNIS\n"
        set param1(dialPlan) true
        leg collectdigits leg_incoming param1 pattern
        media play leg_incoming _welcome.au %s1000 _enter_dest.au
    } else {
        set fcnt 6
    leg setupack leg_incoming
        handoff callappl leg_incoming default "DESTINATION=$dnis"
        fsm setstate HANDOFF
        media play leg_incoming "flash:/aguarde.au"
Hello i try this,
it works but its not playing the audio (en_reenter_dest.au,) after the wrong extension
Leonardo Santana
Leonardo Santana
Hi Leonardo, Try this?
http://www.cisco.com/c/en/us/td/docs/ios/voice/tcl/developer/guide/tclivrv2/tclivrv2_ch5.html
proc act_GotDest { } {
    global dest
    global callInfo
    global oprtr
    global busyPrompt
    puts "\n proc act_GotDest"
    set status [infotag get evt_status]
    set callInfo(alertTime) 30
    if {  ($status == "cd_004") } {
        set dest [infotag get evt_dcdigits]
    if { $dest == "0" } {
        set dest $oprtr
        handoff callappl leg_incoming default "DESTINATION=$dest"
    } elseif { ($status == "cd_001") || ($status == "cd_002") } {
    set dest $oprtr
    }    else {
    if { $status == "cd_006" } {
        set busyPrompt _dest_unreachable.au (--> You can change the prompt here as "Extension entered is not valid")
        act_Select
Now the audio is playing, but its playing two times the message.
Leonardo Santana
Leonardo Santana
Can you try a return after act_Select
        act_Select
          return
I have the same problem.   I have included  the "return" after "act_Select". Could someone check if I did right, if not how can i proceed.
        puts "\nCall [infotag get con_all] got event $status collecting destination"
                set dest $oprtr
        } else {
                act_Select
                return
AddedVGW01#show call application voice pandurata
Script Name : pandurata
       URL  : flash:its-CISCO.2.0.3.0.tcl
       Type : Service
       State: Registered
       Life : Configured
       Exec Instances: 0
Parameters registered under pandurata namespace:
  name                                            type  default value   description
  uid-len                    I     10              the number of digits in UID
  warning-time           I     30              the time (in secs) within which a user is warned before the calling time expires (call terminates)
  pin-len                    I     4               the number of digits in PIN
  retry-count              I     3               the number of attempts to reenter PIN
  redirect-number      S                     the telephone number where a call is redirected to
Script Code Begin:
TCL Script  version 2.0 - 2.1
# Script Locked by: khom
# Script Version: 2.0.1.0
# Script Name: its_CISCO
# Script Lock Date: Wed Jul  2 09:22:04 2003
# November 27, 2001, Satish Ananthanarayana ([email protected])
# Copyright (c) 2001 by cisco Systems, Inc.
# All rights reserved.
# Description:
#       This is a TCL IVR script for the IOS Telephony Service and
#       Call Manager (CM) offload scenario. The IVR script plays a
#       welcome prompt to the user and prompts the user to enter a
#       destination number when the user dials the auto-attendant number
#       (aa-pilot configured in the CLI). The script collects the digits that
#       the user has entered and hands the call to the enhanced session
#       application (named Default).  The session application
#       returns once there is a disconnect (if the call is established)
#       or if a call setup problem occurs.
#       The operator support is also included, if the user does not dial
#       any number or enters "0" the user will be transfered to an operator
#       (if operator number is configured in the CLI). If the user enters
#       an invalid number, the user will be prompted again to re-enter
#       the number for upto 3 times before disconnecting the call.
proc init { } {
    global param1
    global selectCnt
    global callInfo
    global legConnected
    set param1(interruptPrompt) true
    set param1(abortKey) *
    set param1(terminationKey) #
    set param1(initialDigitTimeout) 3
    set param1(interDigitTimeout) 4
    set selectCnt 0
    set legConnected false
proc init_ConfigVars { } {
    global destination
    global aaPilot
    global oprtr
        global param1
        if [infotag get cfg_avpair_exists initial-Digit-Timeout] {
        set param1(initialDigitTimeout) [string trim [infotag get cfg_avpair initial-Digit-Timeout]]
    } else {
if [infotag get cfg_avpair_exists inter-Digit-Timeout] {
        set param1(interDigitTimeout) [string trim [infotag get cfg_avpair inter-Digit-Timeout]]
    } else {
# aa-pilot is the IVR number configured on the gateway to be used by the customer
# operator is the operator number for assisted calling
    if [infotag get cfg_avpair_exists aa-pilot] {
        set aaPilot [string trim [infotag get cfg_avpair aa-pilot]]
    } else {
        set aaPilot "NONE"
    if [infotag get cfg_avpair_exists operator] {
        set oprtr [string trim [infotag get cfg_avpair operator]]
    } else {
        set oprtr "NONE"
proc init_perCallVars { } {
    puts "\nproc init_perCallvars"
    global ani
    global digit_enabled
    global fcnt
    global retrycnt
    global dnis
    set fcnt 0
    set retrycnt 6
    set ani ""
    set dnis ""
    set digit_enabled "FALSE"
    set ani [infotag get leg_ani]
    puts "\nANI $ani"
    set dnis [infotag get leg_dnis]
    puts "\nDNIS $dnis"
    global param1
    global selectCnt
    global dest
    global beep
    global callInfo
    global dnis
    global fcnt
    global aaPilot
    global oprtr
    global busyPrompt
    global legConnected
    set beep 0
    init_perCallVars
        puts "\nNo DNIS\n"
    } else {
        set fcnt 6
    global dest
    global callInfo
    global oprtr
    global busyPrompt
                set dest $oprtr
        set dest $oprtr
    }   else {
                set dest $oprtr
        } else {
                act_Select
                        return
proc act_CallSetupDone { } {
    global busyPrompt
    global legConnected
    set status [infotag get evt_handoff_string]
    if { [string length $status] != 0} {
        regexp {([0-9][0-9][0-9])} $status StatusCode
        puts "IP IVR Disconnect Status = $status"
        switch $StatusCode {
          "016" {
              puts "\n Connection success"
              fsm setstate CONTINUE
              act_Cleanup
          default {
              if { $legConnected == "false" } {
              puts "\n Call failed.  Play prompt and collect digit"
              if { ($StatusCode == "017") } {
                  set busyPrompt _dest_busy.au
              act_Select
    } else {
        puts "\n Caller disconnected"
        fsm setstate CALLDISCONNECT
        act_Cleanup
proc act_Select { } {
    global destination
    global promptFlag2
    global destBusy
    global param1
    global fcnt
    global retrycnt
    global busyPrompt
    puts "\n proc act_Select"
    set promptFlag2 0
    set param1(dialPlanTerm) true
    if { $fcnt < $retrycnt } {
        media play leg_incoming $busyPrompt %s500 _reenter_dest.au
        incr fcnt
        fsm setstate GETDEST
    } else {
        act_DestBusy
proc act_DestBusy { } {
    puts "\n proc act_DestBusy"
    media play leg_incoming _disconnect.au
proc act_Cleanup { } {
    call close
requiredversion 2.0
init
init_ConfigVars
#   State Machine
  set fsm(any_state,ev_disconnected)   "act_Cleanup  same_state"
  set fsm(CALL_INIT,ev_setup_indication) "act_Setup  GETDEST"
  set fsm(GETDEST,ev_collectdigits_done) "act_GotDest HANDOFF"
  set fsm(HANDOFF,ev_returned)   "act_CallSetupDone  CONTINUE"
  set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup  same_state"
  fsm define fsm CALL_INIT
# Script Approval Signature: C/775c
Daniel Sobrinho
