Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
I've successfully installed the Cisco TAPI Wave driver but when I make a call from a CTI port to an extension and call lineGetID() it fails with reason LINEERR_OPERATIONFAILED. This also fails when I try the same operation using the Microsoft TAPI Br...
bhoover02 by • Level 3
  • 639 Views
  • 0 replies
Hi,I have this scenario:2 SCCP phones (A and C) and a Third-party SIP device (B)A calls B and B transfers to C, but when I attempt to transfer I receive the error "destination not found" on device (3cxPhone) and error 491: Request Pending, but if I m...
I'm having trouble installing the TSP for my CUCM 7.0.1. I downloaded the TSP installer from the CUCM admin page and ran it. However, the TSP doesn't appear anywhere. It doesn't show up in my Phone and Modem setting and I can't add it. I tried this o...
  • 1801 Views
  • 1 replies
Dear All,I want to monitor all extensions in a CCM Cluster. As per CCM guid we can do this using Super Provider.As per CCM, we can make any user as Super Provider by giving it right as Standard CTI Allow Control of All Devices user group.I am using a...
Hi,We are calling the CiscoMediaTerminal.register(java.net.InetAddress address, int port, CiscoMediaCapability[] capabilities)during our application startup to register the CTI port for further use .Before we invoke this api we call the isRegistered(...
posenthi by • Community Member
  • 1935 Views
  • 6 replies
We have CUCM 9.1 connected internally to Mitel (MCD 6.0) via SIP.  Transferred calls between the two systems don't display the correct caller ID on Mitel sets.  This is because Mitel uses the FROM field in UPDATE messages for caller ID on sets displa...
rick_declerk by • Community Member
  • 1424 Views
  • 1 replies
Hello, Question:  Can I retrieve the original address when I have a series of CTI ports chained together for call forwarding?Example:CTI x (Line 1 - "111")Forward Unregistered Internal set to "222"CTI y (Line 1 - "222")Forward Unregistered Internal s...
mstromske by • Community Member
  • 1877 Views
  • 1 replies
We're working on a server to receive and handle JTAPI messages from CUCM. In the dev guide, I note that the default behavior of the Cisco JTAPI implementation spawns a new thread for each observer:"Normally, when an application adds a new observer to...
harris.scott by • Community Member
  • 1875 Views
  • 4 replies
  • 1 Helpful votes
HelloWhen dial a wrong extension the message you to reenter the destination did not play, and after a while the call is transfered to the operator.Follow my script.Extension Range: 9xxxHow can i do this?RegardsLeonardo Santana
