What is the operation of callInfo(rerouteMode) ?
paolo bevilacqua
I cannot have this working as described. I set it "none" in conjunction with "mode rotary", but when calling a number that has call forward, there is no notification to the script, call setup continues toward the CF destination.
That is a SIP call and the message "moved temporarily" is received normally.
Is the element name "rerouteMode" the correct one? On page 3-77 there is an example as:
set callInfo(rotaryRedirectMode) “ROTARY”
That doesn't work either.
26 Replies 26
Raghavendra G V
I believe rerouteMode is correct, you can find below description in guide.
– rerouteMode—Possible values are: none / rotary / redirect / redirect_rotary. If not specified, the
value is same as mode. If both this argument and mode are not specified, the default value is
rotary. This parameter does not allow indexing.
You can also find in the logs as below.
*Aug  7 05:09:11.487: //-1//CSPK:/tclSetControlParams: mode(2) = REDIRECT
*Aug  7 05:09:11.487: //13//CSPK:/C_CallSetup_Start: ControlInfo = 0x7824F12C, callInfo = 0x7824F96C, destination[0]=3009
*Aug  7 05:09:11.487: //13//CSPK:/C_CallSetup_Start: configured reroutemode=rotary (1)
Raghavendra
Problem is, as indicated above, that setting rerouteMode to null has no effect. There is no indication to the script as the manual mentions. At least with IOS 15.14 that I've tried with.
When you say no indication to script means, script did not get ev_setup_done event ?.
could you please share us the logs.
Raghavendra
You can use below infotag which Returns forwarding request information when a call is being forwarded.
infotag get evt_redirect_info {redirectDest | redirectReason | redirectCount | originalDest}
Raghavendra
Accessing this infotag on ev_setup_done always generate an error, either destination has CF set or not.
Aug  7 13:15:41.660: //768//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Aug  7 13:15:41.660: TCL script failure
        Result:
Aug  7 13:15:41.660:    TCL script failure errorInfo:
    while executing
"infotag get evt_redirect_info redirectDest"
As mentioned according to the documentation the script is supposed to receive ev_setup_done with a different status code to indicate destination has call forward. That doesn't happen.
I think you should get the status code as "ls_026" when the call is forwarded. What is the status code you got.
Raghavendra
As explained above already, the status is the one related to the final cal destination, for example answered, busy or no answer. Never ls_026.
Note that the destination gateways correctly sends "SIP moved temporarily" and the local router re--invites to the new destination. But the script is never notified.
What is the status code you got when call is forwarded. Is it possible for you to share the logs.
Raghavendra
Again fro my answer above:
Regarding logs they are nothing particular. Just have a script that calls a number with call forwarding and should see that callInfo(rerouteMode) has no effect.
I don't any issues, you can refer below H450 TCL script for rerouteMode Example.
set callInfo(rerouteMode)    NONE
https://software.cisco.com/download/release.html?mdfid=277641082&softwareid=283451126&release=2.0.1.0&rellifecycle=&relind=AVAILABLE&reltype=all
Raghavendra
As mentioned before, I use SIP not H.323 on which H.450 is based.
With SIP, the script is not notified that the destination has set call transfer.
I did try with SIP only, script got notified with status ls_026 and able to get redirect Info.
Raghavendra
See below log where the script never receives ls_026, yet SIP has sent the redirection info, and the gateway acted on it.
IOS 15.1(4) which is the latest available for ISR routers.
This is the test script It is started with "call application session start xxx zzz"
proc sess {} {
  set callInfo(rerouteMode) rotary
  leg setup 202 callinfo
proc setupDone {} { puts [infotag get evt_status] }
set fsm(I,ev_session_indication) {sess same_state}
set fsm(I,ev_setup_done) {setupDone same_state}
fsm define fsm I
----------- LOG
Aug 10 14:01:37.039: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = test
Aug 10 14:01:37.039: //-1//AFW_:/AFW_Process_New: test
Aug 10 14:01:37.039: //-1//AFW_:/AFW_ExecEnv_New:
Aug 10 14:01:37.039: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetRoot: Execenv = 0x69285BE8
Aug 10 14:01:37.039: //-1//AFW_:/AFW_TclModule_New:
Aug 10 14:01:37.039: //-1//AFW_:/AFW_Process_Lock: pProcess(0x690CCF4C)=1
Aug 10 14:01:37.043: //-1//AFW_:LP:EE69285BE8000:HN1E8BD0B4:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
Aug 10 14:01:37.043: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetScript:  Script Name = test,
Aug 10 14:01:37.043: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetScript:    Script URI = ftp://10.0.2.1/test-callinfo.tcl
Aug 10 14:01:37.043: //-1//AFW_:EE69285BE8000:/Tcl_Link: Linking script test
Aug 10 14:01:37.047: //-1//ACPK:EE69285BE8000:/AppCommon_SetSecurity: security = undefined
Aug 10 14:01:37.047: //-1//ACPK:EE69285BE8000:/AppCommon_SetEventLog: event-log = unconfigured
Aug 10 14:01:37.047: //-1//TCL :EE69285BE8000:/tcl_FSMObjCmd:  fsm define fsm I
Aug 10 14:01:37.051: //-1//AFW_:/AFW_FSM_New:
Aug 10 14:01:37.051: //-1//TCL :EE69285BE8000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: I
Aug 10 14:01:37.051: //-1//TCL :EE69285BE8000:/tcl_FSMDefineObjCmd: FSM Data structure
Aug 10 14:01:37.051: (I(1), ev_session_indication(198)--(sess)-->(any_state(0))
Aug 10 14:01:37.051: (I(1), ev_setup_done(219)--(setupDone)-->(any_state(0))
Aug 10 14:01:37.051: FSM start state I(1)
Aug 10 14:01:37.051: //-1//AFW_:EE69285BE8000:/Tcl_Link: Script test succesfully linked.
Aug 10 14:01:37.051: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetScript: Num of packTable entries: 22
Aug 10 14:01:37.051: //-1//AFW_:/AFW_Event_New: Event ID: ev_session_indication
Aug 10 14:01:37.051: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_Initiate: Execenv = 0x69285BE8
Aug 10 14:01:37.051: //-1//SERV:/AFW_Service_Process_Space:
Aug 10 14:01:37.051: Process Started
Aug 10 14:01:37.055: //-1//AFW_:/AFW_Process_Register: ccAppInitialize(name: _ManagedAppProcess_test)
Aug 10 14:01:37.055: //-1//AFW_:EE69285BE8000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 10 14:01:37.055: //-1//AFW_:EE69285BE8000:/AFW_Process_GetAppQEvent: Received
Aug 10 14:01:37.055: //-1//AFW_:/AFW_Process_GetAppQEvent:  Event[APP_EV_SESSION_START_IND(198)] {
Aug 10 14:01:37.055: //-1//AFW_:/AFW_Process_GetAppQEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.055: //-1//AFW_:EE69285BE8000:/AFW_M_Module_GetHandle: Module handle: TclModule_69F32740_0_512479412MOD[TclModule_69F32740_0_512479412]  (
Aug 10 14:01:37.055: //-1//AFW_:/AFW_Process_GetAppQEvent:    )
Aug 10 14:01:37.059: //-1//AFW_:/AFW_Process_GetAppQEvent:  }
Aug 10 14:01:37.059: //-1//AFW_:EE69285BE8000:/AFW_M_TclModule_EventPreProcess:
Aug 10 14:01:37.059: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32740_0_512479412 ---> TclModule_69F32740_0_512479412
Aug 10 14:01:37.059: //-1//AFW_:EE69285BE8000:/AFW_M_TclModule_Action:
Aug 10 14:01:37.059: //-1//AFW_:EE69285BE8000:/AFW_TclModule_DefaultEvHandling:
Aug 10 14:01:37.059: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_session_indication[198])---[sess]------
Aug 10 14:01:37.059: //-1//TCL :EE69285BE8000:/tcl_LegObjCmd:  leg setup 202 callinfo
Aug 10 14:01:37.059: //-1//CSPK:EE69285BE8000:/tcl_LegSetupObjCmd: leg setup 202 callinfo
Aug 10 14:01:37.059: //-1//CSPK:EE69285BE8000:/C_CallSetup_Start: ControlInfo = 0x69F1CCEC, callInfo = 0x69F5DCC8, destination[0]=202
Aug 10 14:01:37.059: //-1//CSPK:EE69285BE8000:/C_CallSetup_Start: configured mode=rotary (1)
Aug 10 14:01:37.059: //-1//CSPK:EE69285BE8000:/C_CallSetup_Start: configured reroutemode=rotary (1)
Aug 10 14:01:37.063: //-1//Call:/AFW_CallSetup_New:
Aug 10 14:01:37.063: //-1//AFW_:/AFW_FSM_New:
Aug 10 14:01:37.063: //-1//AFW_:LP:EE69285BE8000:HN1E8BD0CC:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 0
Aug 10 14:01:37.063: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
Aug 10 14:01:37.063: //-1//AFW_:EE69285BE8000:/AFW_Object_AddListener: adding Module TclModule as listener
Aug 10 14:01:37.063: //-1//AFW_:EE69285BE8000:/AFW_M_Module_GetHandle: Module handle: CallSetup_69137538_0_512479436
Aug 10 14:01:37.063: //-1//Call:EE69285BE8000:/AFW_CallSetup_AddDest:  202 index 0
Aug 10 14:01:37.063: //-1//Call:EE69285BE8000:/AFW_M_CallSetup_Initiate:
Aug 10 14:01:37.063: //-1//Call:EE69285BE8000:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
Aug 10 14:01:37.063: //-1//Call:EE69285BE8000:/CallSetupInitiate:
Aug 10 14:01:37.063: //-1//Call:EE69285BE8000:/CS_Placecall:
Aug 10 14:01:37.063: //-1//Dest:/AFW_Destination_New:
Aug 10 14:01:37.063: //-1//AFW_:LP:EE69285BE8000:HN1E8BD0CC:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
Aug 10 14:01:37.063: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
Aug 10 14:01:37.067: //-1//AFW_:EE69285BE8000:/AFW_Object_AddListener: adding Module CallSetup as listener
Aug 10 14:01:37.067: //-1//AFW_:EE69285BE8000:/AFW_M_Module_GetHandle: Module handle: Destination_69188FD4_0_512479436
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/AFW_Destination_AddDest:
Aug 10 14:01:37.067: //-1//Dest:/AFW_Destination_AddDest: adding destination "202"
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Initiate:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Initiate: Outgoing guid : 62ECE0A7.3E8E11E5.87A8C175.851B1C9E
Aug 10 14:01:37.067:  Incoming_guid : 00000000.00000000.00000000.00000000
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Initiate: Outgoing gcid : 00000000.00000000.00000000.00000000
Aug 10 14:01:37.067:  Incoming_gcid : 00000000.00000000.00000000.00000000
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestSetupInitiate:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestAddRerouteSetupInfo:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestAddTransferSetupInfo:
Aug 10 14:01:37.067: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 202
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestMatchDialPeer:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestMatchDialPeer: src carrier id:, tgt carrier id:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestQueuePeers: Matched peers:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestPeerItemUpdatePreemptInfo:
Aug 10 14:01:37.067: //-1//Dest:EE69285BE8000:/DestPeerItemResetLPCORInfo:
Aug 10 14:01:37.067: //-1//Dest:/DestQueuePeers:  200
Aug 10 14:01:37.067: //-1//Dest:/DestQueuePeers: , Total(1)
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestDialPeerRotary:
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestOutboundCallUsingPeer: dest(202), numexpDest(202), numDestDigits(2)
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestOutboundCallUsingPeer:    prefix(.55), peer tag(200)
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestUpdatePreemptSetupInfo:
Aug 10 14:01:37.071: //-1//AFW_:/AFW_Util_RemovePreemptInfoFromContainer: Failed to remove mlppSetupInfo from TD container
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestDialPeerFilter:
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestDialPeerFilter: Checking peer [200]
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestPeerFilterRouteCode: Route Code not available
Aug 10 14:01:37.071: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(200) calling[] called[202]
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestCheckTeleUnassBusy:
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestHandleLPCOR:
Aug 10 14:01:37.071: //-1//Dest:EE69285BE8000:/DestSetup:
Aug 10 14:01:37.071: //-1//AFW_:/AFW_Leg_GetTypeDetail:  ***ERROR*** pLeg is NULL
Aug 10 14:01:37.071: //-1//AFW_:/AFW_Util_SaveRawMsg:
Aug 10 14:01:37.071: //-1//AFW_:/AFW_Leg_New:
Aug 10 14:01:37.071: //1073/62ECE0A787A8/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
Aug 10 14:01:37.071: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_SetExecEnv:
Aug 10 14:01:37.075: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
Aug 10 14:01:37.075: //-1/62ECE0A787A8/AFW_:LP:EE69285BE8000:LG1073:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 3
Aug 10 14:01:37.075: //1073/62ECE0A787A8/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
Aug 10 14:01:37.075: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_1073
Aug 10 14:01:37.075: //1073/62ECE0A787A8/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 12A type 3
Aug 10 14:01:37.075: //-1//Dest:EE69285BE8000:/DestSetup: Destination setup success
Aug 10 14:01:37.075: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Initiate: attempting call to destination 202
Aug 10 14:01:37.075: //-1//Call:EE69285BE8000:/CS_Placecall: Call placed to 202 index 0
Aug 10 14:01:37.075: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(I[1])---------------
Aug 10 14:01:37.075: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32740_0_512479412 ---> TclModule_69F32740_0_512479412
Aug 10 14:01:37.075: //-1//AFW_:EE69285BE8000:/AFW_M_Event_Free:
Aug 10 14:01:37.075: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 14:01:37.075: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.075: //-1//AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.075: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 10 14:01:37.083: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.083: //1073/62ECE0A787A8/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 14:01:37.087: //-1//AFW_:/AFW_Process_GetCcqEvent:  Event[CC_EV_CALL_PROCEEDING(31)] {
Aug 10 14:01:37.087: //-1//AFW_:/AFW_Process_GetCcqEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.087: //-1//AFW_:/AFW_Process_GetCcqEvent:    LEG[1073][LEG_OUTINIT(7)][Cause(0)]
Aug 10 14:01:37.087: //-1//AFW_:/AFW_Process_GetCcqEvent:  }
Aug 10 14:01:37.087: //1073/62ECE0A787A8/SSIN:/AFW_SS_MapEvent:
Aug 10 14:01:37.087: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 10 14:01:37.087: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1073  ][LEG_OUTINIT(7)][Cause(0)]
Aug 10 14:01:37.087: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners:
Aug 10 14:01:37.087: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.087: //-1//AFW_:/AFW_M_Object_ShowListeners:  MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.087: //-1//AFW_:/AFW_M_Object_ShowListeners:    LEG[1073][LEG_OUTINIT(7)][Cause(0)]
Aug 10 14:01:37.087: //-1//AFW_:/AFW_M_Object_ShowListeners:  )
Aug 10 14:01:37.087: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.087: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 14:01:37.087: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32740_0_512479412 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Action:
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/AFW_Destination_Action:
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/OB_FSM_Drive:
Aug 10 14:01:37.087: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.087: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/OB_Setting_Proceeding:
Aug 10 14:01:37.087: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/IW_FSM_Drive:
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/DestIsEventNotified:
Aug 10 14:01:37.087: //-1//Dest:EE69285BE8000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 10 14:01:37.087: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> TclModule_69F32740_0_512479412
Aug 10 14:01:37.091: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.091: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 14:01:37.091: //1073/62ECE0A787A8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:202@10.160.3.55:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK28824B4
To: <sip:202@10.160.3.55>
Date: Mon, 10 Aug 2015 12:01:37 GMT
Call-ID: 62EF51DF-3E8E11E5-87ABC175-851B1C9E@10.160.3.56
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1659691175-1049498085-2275983733-2233146526
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1439208097
Contact: <sip:10.160.3.56:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 4364 1368 IN IP4 10.160.3.56
s=SIP Call
c=IN IP4 10.160.3.56
t=0 0
m=audio 17608 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 10 14:01:37.103: //1073/62ECE0A787A8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Received:
SIP/2.0 302 Moved Temporarily
To: <sip:202@10.160.3.55>;tag=1E5AF478-22BB
CSeq: 101 INVITE
Diversion: <sip:202@10.160.3.55>;reason=unconditional;counter=1
Contact: <sip:203@10.160.3.55>
Content-Length: 0
Aug 10 14:01:37.111: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 14:01:37.111: //-1//AFW_:/AFW_Process_GetCcqEvent:  Event[CC_EV_CALL_FEATURE(38)] {
Aug 10 14:01:37.111: //-1//AFW_:/AFW_Process_GetCcqEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.111: //-1//AFW_:/AFW_Process_GetCcqEvent:    LEG[1073][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 14:01:37.111: //-1//AFW_:/AFW_Process_GetCcqEvent:  }
Aug 10 14:01:37.111: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1073  ][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners:
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.111: //-1//AFW_:/AFW_M_Object_ShowListeners:  MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.111: //-1//AFW_:/AFW_M_Object_ShowListeners:    LEG[1073][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 14:01:37.111: //-1//AFW_:/AFW_M_Object_ShowListeners:  )
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.111: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 14:01:37.111: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.111: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Action:
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/AFW_Destination_Action:
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/OB_FSM_Drive:
Aug 10 14:01:37.115: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.115: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_feature[38])---[C_Action]------
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/OB_Ignore: IGNORING EVENT
Aug 10 14:01:37.115: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/IW_FSM_Drive:
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/DestIsEventNotified:
Aug 10 14:01:37.115: //-1//Dest:EE69285BE8000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 10 14:01:37.115: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> NULL
Aug 10 14:01:37.115: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.115: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 14:01:37.115: //1073/62ECE0A787A8/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:202@10.160.3.55:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 10 14:01:37.119: //1073/62ECE0A787A8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:203@10.160.3.55:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK28912FF
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 268
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 10 14:01:37.131: //1073/62ECE0A787A8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Received:
SIP/2.0 503 Service Unavailable
To: <sip:202@10.160.3.55>;tag=1E5AF494-12AB
CSeq: 102 INVITE
Diversion: <sip:203@10.160.3.55>;reason=unconditional;counter=2
Content-Length: 0
Aug 10 14:01:37.135: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.135: //1073/62ECE0A787A8/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 14:01:37.135: //-1//AFW_:/AFW_Process_GetCcqEvent:  Event[CC_EV_CALL_DISCONNECTED(20)] {
Aug 10 14:01:37.135: //-1//AFW_:/AFW_Process_GetCcqEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.135: //-1//AFW_:/AFW_Process_GetCcqEvent:    LEG[1073][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 14:01:37.135: //-1//AFW_:/AFW_Process_GetCcqEvent:  }
Aug 10 14:01:37.135: //1073/62ECE0A787A8/SSIN:/AFW_SS_MapEvent:
Aug 10 14:01:37.135: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 10 14:01:37.135: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners:
Aug 10 14:01:37.135: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.135: //-1//AFW_:/AFW_M_Object_ShowListeners:  MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.135: //-1//AFW_:/AFW_M_Object_ShowListeners:    LEG[1073][LEG_OUTPROCEED(8)][Cause(63)]
Aug 10 14:01:37.139: //-1//AFW_:/AFW_M_Object_ShowListeners:  )
Aug 10 14:01:37.139: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.139: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 14:01:37.139: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Action:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/AFW_Destination_Action:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/OB_FSM_Drive:
Aug 10 14:01:37.139: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.139: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_disconnected[20])---[C_Action]------
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/OB_Setting_Disconnected:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/OBDiscContinue:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/resetAppAlertTimer:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/Dest_AAA_CheckAccounting:
Aug 10 14:01:37.139: //-1//Dest:EE69285BE8000:/Dest_AAA_CheckAccounting: accounting to be enabled for callID=1073
Aug 10 14:01:37.139: //1073/62ECE0A787A8/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_1073
Aug 10 14:01:37.139: //1073/62ECE0A787A8/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_1073, Cause 63
Aug 10 14:01:37.139: //1073/62ECE0A787A8/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 12A type 2
Aug 10 14:01:37.139: //-1//Dest:/DestStatusFromDiscCause: mapped "service or option not available unspecified (63)"(63) to DEST_NUMBER_BLOCKED(18)
Aug 10 14:01:37.143: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DISCONNECTING[6])---------------
Aug 10 14:01:37.143: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.143: //-1//Dest:EE69285BE8000:/IW_FSM_Drive:
Aug 10 14:01:37.143: //-1//Dest:EE69285BE8000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 14:01:37.143: //-1//Dest:EE69285BE8000:/DestIsEventNotified:
Aug 10 14:01:37.143: //-1//Dest:EE69285BE8000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_DISCONNECTING
Aug 10 14:01:37.143: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> NULL
Aug 10 14:01:37.143: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.143: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 14:01:37.147: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 14:01:37.147: //-1//AFW_:/AFW_Process_GetCcqEvent:  Event[CC_EV_CALL_DISCONNECT_DONE(21)] {
Aug 10 14:01:37.147: //-1//AFW_:/AFW_Process_GetCcqEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.147: //-1//AFW_:/AFW_Process_GetCcqEvent:    LEG[1073][LEG_OUTDISCONNECTING(11)][Cause(63)]
Aug 10 14:01:37.147: //-1//AFW_:/AFW_Process_GetCcqEvent:  }
Aug 10 14:01:37.147: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners:
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.147: //-1//AFW_:/AFW_M_Object_ShowListeners:  MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.147: //-1//AFW_:/AFW_M_Object_ShowListeners:    LEG[1073][LEG_DISCONNECTED(12)][Cause(63)]
Aug 10 14:01:37.147: //-1//AFW_:/AFW_M_Object_ShowListeners:  )
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 14:01:37.147: //1073/62ECE0A787A8/AFW_:/AFW_Object_RemoveListener:
Aug 10 14:01:37.147: //-1//AFW_:EE69285BE8000:/AFW_Module_UnListen:  NumObjects: 0
Aug 10 14:01:37.147: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.147: //-1//Dest:EE69285BE8000:/AFW_M_Destination_Action:
Aug 10 14:01:37.147: //-1//Dest:EE69285BE8000:/AFW_Destination_Action:
Aug 10 14:01:37.147: //-1//Dest:EE69285BE8000:/OB_FSM_Drive:
Aug 10 14:01:37.147: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_DISCONNECTING[6],ev_disconnect_done[21])---[C_Action]------
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/OB_Disconnecting_DiscDone:
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/DestDialPeerRotary:
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/OB_Disconnecting_DiscDone: no more dialpeers or all dialpeers failed
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> Destination_69188FD4_0_512479436
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/IW_FSM_Drive:
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/DestIsEventNotified:
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_DONE
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/DestUpdateMLPPCause: status=18, cause=63, prUserStat=0, prTrunkStat=0
Aug 10 14:01:37.151: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_Module_ReturnArgEv:
Aug 10 14:01:37.151: //-1//Dest:EE69285BE8000:/DestReturn: Destination Returning(ds_018 Status DEST_NUMBER_BLOCKED)
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: Destination_69188FD4_0_512479436 ---> NULL
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_Object_WalkListeners:
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free:  CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_1073
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_Object_RemoveAllListener:
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 2
Aug 10 14:01:37.151: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 2
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 3
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_Free:
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/AFW_M_Leg_Free: LEG[1073  ][LEG_DISCONNECTED(12)][Cause(63)]
Aug 10 14:01:37.151: //1073/62ECE0A787A8/AFW_:/decrementDialPeerCallStats: Decrementing call-stat to [0], dial-peer [200]
Aug 10 14:01:37.151: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Process_GetPriorityQEvent: Received
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Process_GetPriorityQEvent:  Event[APP_EV_DESTINATION_DONE(221)] {
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Process_GetPriorityQEvent:    EXECENV[0x69285BE8][test]
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Process_GetPriorityQEvent:    MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Process_GetPriorityQEvent:    )
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Process_GetPriorityQEvent:  }
Aug 10 14:01:37.155: //-1//Dest:EE69285BE8000:/AFW_M_Destination_EventPreProcess:
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Object_WalkListeners:
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_M_Object_ShowListeners: START
Aug 10 14:01:37.155: //-1//AFW_:/AFW_M_Object_ShowListeners:  MOD[CallSetup_69137538_0_512479436]  (
Aug 10 14:01:37.155: //-1//AFW_:/AFW_M_Object_ShowListeners:    MOD[Destination_69188FD4_0_512479436]  (
Aug 10 14:01:37.155: //-1//AFW_:/AFW_M_Object_ShowListeners:    )
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_M_Object_ShowListeners: END
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Object_WalkListeners: Entering Module : CallSetup
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Object_RemoveListener:
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Module_UnListen:  NumObjects: 0
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_69137538_0_512479436
Aug 10 14:01:37.155: //-1//Call:EE69285BE8000:/AFW_M_CallSetup_Action:
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[221])---[C_Action]------
Aug 10 14:01:37.155: //-1//Call:EE69285BE8000:/CS_Placecall_DestDone:
Aug 10 14:01:37.155: //-1//Call:EE69285BE8000:/CS_DestDone_CapturePreemptStatus: PreemptErrorCode 0; Play prompt none
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
Aug 10 14:01:37.155: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done
Aug 10 14:01:37.155: //-1//AFW_:EE69285BE8000:/AFW_Module_ReturnArgEv:
Aug 10 14:01:37.159: //-1//Call:EE69285BE8000:/CS_Complete:
Aug 10 14:01:37.175: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 14:01:37.175: //-1//AFW_:/AFW_M_Event_Free:
Aug 10 14:01:37.175: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
You need to use as below.
proc sess {} {
   leg setup 202 callInfo
Raghavendra
