What is the operation of callInfo(rerouteMode) ?
paolo bevilacqua
I cannot have this working as described. I set it "none" in conjunction with "mode rotary", but when calling a number that has call forward, there is no notification to the script, call setup continues toward the CF destination.
That is a SIP call and the message "moved temporarily" is received normally.
Is the element name "rerouteMode" the correct one? On page 3-77 there is an example as:
set callInfo(rotaryRedirectMode) “ROTARY”
That doesn't work either.
26 Replies 26
As I have mentioned in my opening post, I'm using "none".
The script above has "rotary" for the purpose of generating a comparison with NONE.
Here again the logs when using NONE. They are the same as when using rotary".
Status code never indicates call forward.
Aug 10 15:32:46.792: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = test
Aug 10 15:32:46.792: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
Aug 10 15:32:46.792: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetRoot: Execenv = 0x67B8F67C
Aug 10 15:32:46.792: //-1//AFW_:/AFW_M_TclModule_NewDup:
Aug 10 15:32:46.792: //-1//AFW_:HN1EDD1CD4:/AFW_M_TclModule_Free:
Aug 10 15:32:46.796: //-1//AFW_:HN1EDD1CD4:/AFW_M_Module_GetHandle: Module handle: TclModule_69F322F0_0_517807316MOD[TclModule_69F322F0_0_517807316]        ( )
Aug 10 15:32:46.796: //-1//AFW_:/AFW_M_FSM_Free:
Aug 10 15:32:46.796: //-1//AFW_:/AFW_Process_Lock: pProcess(0x690CCFCC)=1
Aug 10 15:32:46.796: //-1//AFW_:LP:EE67B8F67C000:HN1EDF48E4:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
Aug 10 15:32:46.796: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
Aug 10 15:32:46.796: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
Aug 10 15:32:46.796: //-1//AFW_:/AFW_Event_New: Event ID: ev_session_indication
Aug 10 15:32:46.796: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_Initiate: Execenv = 0x67B8F67C
Aug 10 15:32:46.796: //-1//AFW_:EE67B8F67C000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 10 15:32:46.796: //-1//AFW_:EE67B8F67C000:/AFW_Process_GetAppQEvent: Received
Aug 10 15:32:46.800: //-1//AFW_:/AFW_Process_GetAppQEvent:   Event[APP_EV_SESSION_START_IND(198)] {
Aug 10 15:32:46.800: //-1//AFW_:/AFW_Process_GetAppQEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_M_Module_GetHandle: Module handle: TclModule_69F31770_0_517949668MOD[TclModule_69F31770_0_517949668]  (
Aug 10 15:32:46.800: //-1//AFW_:/AFW_Process_GetAppQEvent:     )
Aug 10 15:32:46.800: //-1//AFW_:/AFW_Process_GetAppQEvent:   }
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_M_TclModule_EventPreProcess:
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: TclModule_69F31770_0_517949668 ---> TclModule_69F31770_0_517949668
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_M_TclModule_Action:
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_TclModule_DefaultEvHandling:
Aug 10 15:32:46.800: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_session_indication[198])---[sess]------
Aug 10 15:32:46.800: //-1//TCL :EE67B8F67C000:/tcl_LegObjCmd:  leg setup 202 callinfo
Aug 10 15:32:46.800: //-1//CSPK:EE67B8F67C000:/tcl_LegSetupObjCmd: leg setup 202 callinfo
Aug 10 15:32:46.804: //-1//CSPK:EE67B8F67C000:/C_CallSetup_Start: ControlInfo = 0x69FE6480, callInfo = 0x69F9C774, destination[0]=202
Aug 10 15:32:46.804: //-1//CSPK:EE67B8F67C000:/C_CallSetup_Start: configured mode=rotary (1)
Aug 10 15:32:46.804: //-1//CSPK:EE67B8F67C000:/C_CallSetup_Start: configured reroutemode=rotary (1)
Aug 10 15:32:46.804: //-1//Call:/AFW_CallSetup_New:
Aug 10 15:32:46.804: //-1//AFW_:/AFW_FSM_New:
Aug 10 15:32:46.804: //-1//AFW_:LP:EE67B8F67C000:HN1EDF48F0:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 0
Aug 10 15:32:46.804: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
Aug 10 15:32:46.804: //-1//AFW_:EE67B8F67C000:/AFW_Object_AddListener: adding Module TclModule as listener
Aug 10 15:32:46.804: //-1//AFW_:EE67B8F67C000:/AFW_M_Module_GetHandle: Module handle: CallSetup_69139C08_0_517949680
Aug 10 15:32:46.804: //-1//Call:EE67B8F67C000:/AFW_CallSetup_AddDest:  202 index 0
Aug 10 15:32:46.804: //-1//Call:EE67B8F67C000:/AFW_M_CallSetup_Initiate:
Aug 10 15:32:46.804: //-1//Call:EE67B8F67C000:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
Aug 10 15:32:46.804: //-1//Call:EE67B8F67C000:/CallSetupInitiate:
Aug 10 15:32:46.804: //-1//Call:EE67B8F67C000:/CS_Placecall:
Aug 10 15:32:46.808: //-1//Call:EE67B8F67C000:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
Aug 10 15:32:46.808: //-1//Dest:/AFW_Destination_New:
Aug 10 15:32:46.808: //-1//AFW_:/AFW_FSM_New:
Aug 10 15:32:46.808: //-1//AFW_:LP:EE67B8F67C000:HN1EDF48F4:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
Aug 10 15:32:46.808: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
Aug 10 15:32:46.808: //-1//AFW_:EE67B8F67C000:/AFW_Object_AddListener: adding Module CallSetup as listener
Aug 10 15:32:46.808: //-1//AFW_:EE67B8F67C000:/AFW_M_Module_GetHandle: Module handle: Destination_69151204_0_517949684
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/AFW_Destination_AddDest:
Aug 10 15:32:46.808: //-1//Dest:/AFW_Destination_AddDest: adding destination "202"
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Initiate:
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Initiate: Outgoing guid : 1F25020B.3E9B11E5.87B0C175.851B1C9E
Aug 10 15:32:46.808:  Incoming_guid : 00000000.00000000.00000000.00000000
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Initiate: Outgoing gcid : 00000000.00000000.00000000.00000000
Aug 10 15:32:46.808:  Incoming_gcid : 00000000.00000000.00000000.00000000
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/DestSetupInitiate:
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/DestAddRerouteSetupInfo:
Aug 10 15:32:46.808: //-1//Dest:EE67B8F67C000:/DestAddTransferSetupInfo:
Aug 10 15:32:46.812: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 202
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestMatchDialPeer:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestMatchDialPeer: src carrier id:, tgt carrier id:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestQueuePeers: Matched peers:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestPeerItemUpdatePreemptInfo:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestPeerItemResetLPCORInfo:
Aug 10 15:32:46.812: //-1//Dest:/DestQueuePeers:  200
Aug 10 15:32:46.812: //-1//Dest:/DestQueuePeers: , Total(1)
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestDialPeerRotary:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestOutboundCallUsingPeer: dest(202), numexpDest(202), numDestDigits(2)
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestOutboundCallUsingPeer:    prefix(.55), peer tag(200)
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestUpdatePreemptSetupInfo:
Aug 10 15:32:46.812: //-1//AFW_:/AFW_Util_RemovePreemptInfoFromContainer: Failed to remove mlppSetupInfo from TD container
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestDialPeerFilter:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestDialPeerFilter: Checking peer [200]
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestPeerFilterRouteCode: Route Code not available
Aug 10 15:32:46.812: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(200) calling[] called[202]
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestCheckTeleUnassBusy:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestHandleLPCOR:
Aug 10 15:32:46.812: //-1//Dest:EE67B8F67C000:/DestSetup:
Aug 10 15:32:46.812: //-1//AFW_:/AFW_Leg_GetTypeDetail:  ***ERROR*** pLeg is NULL
Aug 10 15:32:46.812: //-1//AFW_:/AFW_Util_SaveRawMsg:
Aug 10 15:32:46.812: //-1//AFW_:/AFW_Leg_New:
Aug 10 15:32:46.816: //1075/1F25020B87B0/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
Aug 10 15:32:46.816: //1075/1F25020B87B0/AFW_:/AFW_M_Leg_SetExecEnv:
Aug 10 15:32:46.816: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
Aug 10 15:32:46.816: //-1/1F25020B87B0/AFW_:LP:EE67B8F67C000:LG1075:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 3
Aug 10 15:32:46.816: //1075/1F25020B87B0/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
Aug 10 15:32:46.816: //1075/1F25020B87B0/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_1075
Aug 10 15:32:46.816: //1075/1F25020B87B0/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 12C type 3
Aug 10 15:32:46.816: //-1//Dest:EE67B8F67C000:/DestSetup: Destination setup success
Aug 10 15:32:46.816: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Initiate: attempting call to destination 202
Aug 10 15:32:46.816: //-1//Call:EE67B8F67C000:/CS_Placecall: Call placed to 202 index 0
Aug 10 15:32:46.816: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(I[1])---------------
Aug 10 15:32:46.816: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: TclModule_69F31770_0_517949668 ---> TclModule_69F31770_0_517949668
Aug 10 15:32:46.816: //-1//AFW_:EE67B8F67C000:/AFW_M_Event_Free:
Aug 10 15:32:46.816: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 15:32:46.816: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:46.816: //-1//AFW_:/AFW_M_Event_Free:
Aug 10 15:32:46.820: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 10 15:32:46.824: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 15:32:46.828: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
Aug 10 15:32:46.828: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:46.828: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1075][LEG_OUTINIT(7)][Cause(0)]
Aug 10 15:32:46.828: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 10 15:32:46.828: //1075/1F25020B87B0/SSIN:/AFW_SS_MapEvent:
Aug 10 15:32:46.828: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1075   ][LEG_OUTINIT(7)][Cause(0)]
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners:
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:46.828: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:46.828: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1075][LEG_OUTINIT(7)][Cause(0)]
Aug 10 15:32:46.828: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:46.828: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 15:32:46.828: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: TclModule_69F31770_0_517949668 ---> Destination_69151204_0_517949684
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Action:
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/AFW_Destination_Action:
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/OB_FSM_Drive:
Aug 10 15:32:46.828: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> Destination_69151204_0_517949684
Aug 10 15:32:46.828: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/OB_Setting_Proceeding:
Aug 10 15:32:46.828: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive:
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/DestIsEventNotified:
Aug 10 15:32:46.828: //-1//Dest:EE67B8F67C000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 10 15:32:46.828: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> TclModule_69F31770_0_517949668
Aug 10 15:32:46.832: //1075/1F25020B87B0/AFW_:/AFW_M_Event_Free:
Aug 10 15:32:46.832: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 15:32:46.832: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:202@10.160.3.55:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK28E1BFA
To: <sip:202@10.160.3.55>
Date: Mon, 10 Aug 2015 13:32:46 GMT
Call-ID: 1F280ED2-3E9B11E5-87B3C175-851B1C9E@10.160.3.56
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0522519051-1050350053-2276508021-2233146526
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1439213566
Contact: <sip:10.160.3.56:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 267
v=0
o=CiscoSystemsSIP-GW-UserAgent 278 8518 IN IP4 10.160.3.56
s=SIP Call
c=IN IP4 10.160.3.56
t=0 0
m=audio 16384 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 10 15:32:46.844: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Received:
SIP/2.0 302 Moved Temporarily
To: <sip:202@10.160.3.55>;tag=1EAE6A9C-E78
CSeq: 101 INVITE
Diversion: <sip:202@10.160.3.55>;reason=unconditional;counter=1
Contact: <sip:203@10.160.3.55>
Content-Length: 0
Aug 10 15:32:46.852: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 15:32:46.852: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_FEATURE(38)] {
Aug 10 15:32:46.852: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:46.852: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1075][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 15:32:46.852: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 10 15:32:46.852: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1075   ][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners:
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:46.852: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:46.852: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1075][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 15:32:46.852: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:46.852: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 15:32:46.852: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69151204_0_517949684
Aug 10 15:32:46.852: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Action:
Aug 10 15:32:46.852: //-1//Dest:EE67B8F67C000:/AFW_Destination_Action:
Aug 10 15:32:46.852: //-1//Dest:EE67B8F67C000:/OB_FSM_Drive:
Aug 10 15:32:46.856: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> Destination_69151204_0_517949684
Aug 10 15:32:46.856: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_feature[38])---[C_Action]------
Aug 10 15:32:46.856: //-1//Dest:EE67B8F67C000:/OB_Ignore: IGNORING EVENT
Aug 10 15:32:46.856: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 10 15:32:46.856: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive:
Aug 10 15:32:46.856: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 15:32:46.856: //-1//Dest:EE67B8F67C000:/DestIsEventNotified:
Aug 10 15:32:46.856: //-1//Dest:EE67B8F67C000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 10 15:32:46.856: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> NULL
Aug 10 15:32:46.856: //1075/1F25020B87B0/AFW_:/AFW_M_Event_Free:
Aug 10 15:32:46.856: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 15:32:46.856: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:202@10.160.3.55:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 10 15:32:46.860: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:203@10.160.3.55:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK28F1199
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 267
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 10 15:32:46.872: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Aug 10 15:32:46.876: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:202@10.160.3.55>;tag=1EAE6ABC-1275
CSeq: 102 INVITE
Require: 100rel
RSeq: 1785
Remote-Party-ID: "Ext. twozerothree" <sip:203@10.160.3.55>;party=called;screen=no;privacy=off
Contact: <sip:203@10.160.3.55:5060>
Content-Length: 0
Aug 10 15:32:46.880: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:46.880: //1075/1F25020B87B0/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 15:32:46.880: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_ALERT(16)] {
Aug 10 15:32:46.880: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:46.880: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1075][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 15:32:46.880: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 10 15:32:46.880: //1075/1F25020B87B0/SSIN:/AFW_SS_MapEvent:
Aug 10 15:32:46.880: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 10 15:32:46.880: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners:
Aug 10 15:32:46.880: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:46.880: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:46.880: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1075][LEG_OUTPROCEED(8)][Cause(0)]
Aug 10 15:32:46.880: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 10 15:32:46.880: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:46.880: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 15:32:46.880: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69151204_0_517949684
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Action:
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/AFW_Destination_Action:
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/OB_FSM_Drive:
Aug 10 15:32:46.884: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> Destination_69151204_0_517949684
Aug 10 15:32:46.884: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_alert[16])---[C_Action]------
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/OB_Setting_Alert:
Aug 10 15:32:46.884: //-1//Dest:/OB_Setting_Alert: aData bitmask 0x80000001
Aug 10 15:32:46.884: //-1//Dest:/OB_Setting_Alert: aData.display_info=Ext. twozerothree
Aug 10 15:32:46.884: //1075/1F25020B87B0/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 10 15:32:46.884: //1075/1F25020B87B0/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 10 15:32:46.884: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive:
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/DestIsEventNotified:
Aug 10 15:32:46.884: //-1//Dest:EE67B8F67C000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 10 15:32:46.884: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> NULL
Aug 10 15:32:46.884: //1075/1F25020B87B0/AFW_:/AFW_M_Event_Free:
Aug 10 15:32:46.884: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 15:32:46.940: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:203@10.160.3.55:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK290FE
CSeq: 103 PRACK
RAck: 1785 102 INVITE
Max-Forwards: 70
Content-Length: 0
Aug 10 15:32:46.944: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Aug 10 15:32:50.355: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 5624 8833 IN IP4 10.160.3.55
s=SIP Call
c=IN IP4 10.160.3.55
t=0 0
m=audio 17530 RTP/AVP 0 19 101
a=rtpmap:19 CN/8000
a=fmtp:101 0-16
a=ptime:20
Aug 10 15:32:50.363: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 10 15:32:50.363: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_CONNECTED(17)] {
Aug 10 15:32:50.363: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:50.363: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1075][LEG_OUTRINGING(9)][Cause(0)]
Aug 10 15:32:50.363: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 10 15:32:50.363: //1075/1F25020B87B0/SSIN:/AFW_SS_MapEvent:
Aug 10 15:32:50.363: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 12C type 1
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners:
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:50.363: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:50.363: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1075][LEG_OUTCONNECTED(10)][Cause(0)]
Aug 10 15:32:50.363: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:50.363: //1075/1F25020B87B0/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_69151204_0_517949684
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_Action:
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/AFW_Destination_Action:
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/OB_FSM_Drive:
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> Destination_69151204_0_517949684
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_connected[17])---[C_Action]------
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/OB_Setting_Connect:
Aug 10 15:32:50.367: //-1//Dest:/OB_Setting_Connect: cData.display_info=Ext. twozerothree
Aug 10 15:32:50.367: //1075/1F25020B87B0/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 10 15:32:50.367: //1075/1F25020B87B0/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/DestNotifySharedLnState: callid: 1075, peer: 200
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/DestNotifySharedLnState: Shared-Line NOT enabled!
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive:
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/DestIsEventNotified:
Aug 10 15:32:50.367: //-1//Dest:EE67B8F67C000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_DONE
Aug 10 15:32:50.367: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_Module_ReturnArgEv:
Aug 10 15:32:50.367: //-1//AFW_:EE67B8F67C000:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[1075   ][LEG_OUTCONNECTED(10)][Cause(0)]}
Aug 10 15:32:50.371: //1075/1F25020B87B0/AFW_:/AFW_Object_RemoveListener:
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_Module_UnListen:  NumObjects: 0
Aug 10 15:32:50.371: //-1//Dest:EE67B8F67C000:/DestReturn: Destination Returning(ds_000 Status DEST_ACTIVE)
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: Destination_69151204_0_517949684 ---> NULL
Aug 10 15:32:50.371: //1075/1F25020B87B0/AFW_:/AFW_M_Event_Free:
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_Process_GetPriorityQEvent: Received
Aug 10 15:32:50.371: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(221)] {
Aug 10 15:32:50.371: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:50.371: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:50.371: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
Aug 10 15:32:50.371: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
Aug 10 15:32:50.371: //-1//Dest:EE67B8F67C000:/AFW_M_Destination_EventPreProcess:
Aug 10 15:32:50.371: //1075/1F25020B87B0/Dest:/DestUpdateSuccessStats:
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_Object_WalkListeners:
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:50.371: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_69139C08_0_517949680]  (
Aug 10 15:32:50.371: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_69151204_0_517949684]  (
Aug 10 15:32:50.371: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
Aug 10 15:32:50.371: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Object_WalkListeners: Entering Module : CallSetup
Aug 10 15:32:50.375: //1075/1F25020B87B0/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Object_RemoveListener:
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Module_UnListen:  NumObjects: 1
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_69139C08_0_517949680
Aug 10 15:32:50.375: //-1//Call:EE67B8F67C000:/AFW_M_CallSetup_Action:
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[221])---[C_Action]------
Aug 10 15:32:50.375: //-1//Call:EE67B8F67C000:/CS_Placecall_DestDone:
Aug 10 15:32:50.375: //-1//Call:EE67B8F67C000:/CS_DestDone_CapturePreemptStatus: PreemptErrorCode 0; Play prompt none
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
Aug 10 15:32:50.375: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Module_ReturnArgEv:
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[1075   ][LEG_OUTCONNECTED(10)][Cause(0)]}
Aug 10 15:32:50.375: //1075/1F25020B87B0/AFW_:/AFW_Object_RemoveListener:
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Module_UnListen:  NumObjects: 0
Aug 10 15:32:50.375: //-1//Call:EE67B8F67C000:/CS_Complete: CallSetup Returning(ls_000 Status CS_ACTIVE)
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: CallSetup_69139C08_0_517949680 ---> NULL
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_M_Event_Free:
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_69151204_0_517949684
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_Object_RemoveAllListener:
Aug 10 15:32:50.375: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 3
Aug 10 15:32:50.375: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 2
Aug 10 15:32:50.375: //-1//AFW_:HN1EDF48F4:/AFW_M_Event_Free: ExecEnv objCount: 3
Aug 10 15:32:50.375: //-1//Dest:HN1EDF48F4:/AFW_M_Destination_Free:
Aug 10 15:32:50.379: //-1//Dest:HN1EDF48F4:/DestEmptyPreemptHoldQ:
Aug 10 15:32:50.379: //-1//AFW_:/AFW_M_FSM_Free:
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_Process_GetPriorityQEvent: Received
Aug 10 15:32:50.379: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(219)] {
Aug 10 15:32:50.379: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x67B8F67C][test]
Aug 10 15:32:50.379: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_69139C08_0_517949680]  (
Aug 10 15:32:50.379: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
Aug 10 15:32:50.379: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
Aug 10 15:32:50.379: //-1//Call:EE67B8F67C000:/AFW_M_CallSetup_EventPreProcess:
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_Object_WalkListeners:
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:50.379: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_69F31770_0_517949668]  (
Aug 10 15:32:50.379: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_69139C08_0_517949680]  (
Aug 10 15:32:50.379: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_Object_WalkListeners: Entering Module : TclModule
Aug 10 15:32:50.379: //1075/1F25020B87B0/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
Aug 10 15:32:50.379: //-1//AFW_:EE67B8F67C000:/AFW_Object_RemoveListener:
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_Module_UnListen:  NumObjects: 1
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_69F31770_0_517949668
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_M_TclModule_Action:
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_TclModule_DefaultEvHandling:
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [1075]'s session
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_setup_done[219])---[setupDone]------
Aug 10 15:32:50.383: //-1//TCL :EE67B8F67C000:/tcl_InfotagObjCmd:  infotag get evt_status
Aug 10 15:32:50.383: //-1//TCL :EE67B8F67C000:/tcl_InfotagGetObjCmd: infotag get evt_status
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/vtr_ev_status: argc 2 argindex 2
Aug 10 15:32:50.383: //-1//TCL :EE67B8F67C000:/tcl_PutsObjCmd: ls_000
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_FSM_Drive: ACTION END: -------------(I[1])---------------
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_SetModuleScope: TclModule_69F31770_0_517949668 ---> NULL
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_Object_WalkListeners:
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: START
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_M_Object_ShowListeners: END
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_M_Event_Free:
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_69139C08_0_517949680
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_Object_RemoveAllListener:
Aug 10 15:32:50.383: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 2, CmdPending 2
Aug 10 15:32:50.383: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 1
Aug 10 15:32:50.383: //-1//AFW_:HN1EDF48F0:/AFW_M_Event_Free: ExecEnv objCount: 2
Aug 10 15:32:50.383: //-1//Call:HN1EDF48F0:/AFW_M_CallSetup_Free:
Aug 10 15:32:50.383: //-1//AFW_:/AFW_M_FSM_Free:
Aug 10 15:32:50.387: //-1//AFW_:EE67B8F67C000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
Aug 10 15:32:50.387: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 10 15:32:50.387: //-1//AFW_:/AFW_M_Event_Free:
Aug 10 15:32:50.387: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 10 15:32:50.387: //1075/1F25020B87B0/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK291126
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
I tried your script with NONE, i did received the status code(ls_026).In your log rerouteMode set as rotary. looks like CallInfo
passing to leg setup is different than the variable.
Your log
My log
*Aug 11 04:49:28.116: //-1//AFW_:EE4F02F014000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_session_indication[195])---[sess]------
*Aug 11 04:49:28.116: //-1//TCL :EE4F02F014000:/tcl_LegObjCmd:  leg setup 300 callInfo
*Aug 11 04:49:28.116: //-1//CSPK:EE4F02F014000:/tcl_LegSetupObjCmd: leg setup 300 callInfo
*Aug 11 04:49:28.116: //-1//CSPK:/tclSetControlParams: rerouteMode(5) = NONE
*Aug 11 04:49:28.116: //-1//CSPK:EE4F02F014000:/C_CallSetup_Start: ControlInfo = 0x4F04D090, callInfo = 0x4F047780, destination[0]=300
*Aug 11 04:49:28.116: //-1//CSPK:EE4F02F014000:/C_CallSetup_Start: configured mode=rotary (1)
Raghavendra
Which IOS version are you using? Can you try 15.2(4)M9 ?
I tried in 151-4.M1.
Raghavendra
Can you try 15.1(4)M10 which has ED status ?
Cisco.com does not allow to dowload 15.1(4)M1 with the following message, followed by a long list of bugs-
Cisco engineering has identified at least one serious software issue with the release which you have selected that may affect your use of these software.
Issue is not with IOS, you need to change the script as mentioned in my above posts.
Raghavendra
Thanks, I have correct a typo in the script. Still router receives ls_000 not ls_026.
Check logs below for bold:
BWS-2801#sh ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 15.1(4)M9, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 12-Sep-14 11:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
BWS-2801 uptime is 6 days, 23 hours, 36 minutes
System restarted at 15:41:05 CEST Tue Aug 4 2015
System image file is "flash:c2801-spservicesk9-mz.151-4.M9.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 7.0) with 241664K/20480K bytes of memory.
Processor board ID FCZ11429476
2 FastEthernet interfaces
2 Voice FXS interfaces
2 DSPs, 16 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#  PID                  SN
*0        CISCO2801            FCZ11429476
BWS-2801#sh call application voice test
Script Name : test
      URL  : ftp://10.160.3.249/test-callinfo.tcl
      Type : Service
      State: Registered
      Life : Configured
      Exec Instances: 0
  Parameters registered under test namespace:
  name                type  default value  description
  uid-len              I    10              the number of digits in UID
  warning-time        I    30              the time (in secs) within which a user is warned before the calling time expires (call terminates)
  pin-len              I    4              the number of digits in PIN
  retry-count          I    3              the number of attempts to reenter PIN
  redirect-number      S                    the telephone number where a call is redirected to
Script Code Begin:
TCL Script  version 2.0 - 2.1
proc sess {} {
        set callInfo(rerouteMode) NONE
        leg setup 202 callInfo
proc setupDone {} { puts [infotag get evt_status] }
set fsm(I,ev_session_indication) {sess same_state}
set fsm(I,ev_setup_done) {setupDone same_state}
fsm define fsm I
BWS-2801#call application sess start a test
BWS-2801#
Aug 11 15:33:16.847: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = test
Aug 11 15:33:16.847: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
Aug 11 15:33:16.847: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetRoot: Execenv = 0x69285A18
Aug 11 15:33:16.851: //-1//AFW_:/AFW_M_TclModule_NewDup:
Aug 11 15:33:16.851: //-1//AFW_:HN2405DF1C:/AFW_M_TclModule_Free:  MOD[TclModule_69F31D30_0_604121448]  ( )
Aug 11 15:33:16.851: //-1//AFW_:/AFW_M_FSM_Free:
Aug 11 15:33:16.851: //-1//AFW_:/AFW_Process_Lock: pProcess(0x690CCB4C)=1
Aug 11 15:33:16.851: //-1//AFW_:LP:EE69285A18000:HN24063974:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
Aug 11 15:33:16.851: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
Aug 11 15:33:16.851: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
Aug 11 15:33:16.851: //-1//AFW_:/AFW_Event_New: Event ID: ev_session_indication
Aug 11 15:33:16.851: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_Initiate: Execenv = 0x69285A18
Aug 11 15:33:16.851: //-1//AFW_:EE69285A18000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_Process_GetAppQEvent: Received
Aug 11 15:33:16.855: //-1//AFW_:/AFW_Process_GetAppQEvent:   Event[APP_EV_SESSION_START_IND(198)] {
Aug 11 15:33:16.855: //-1//AFW_:/AFW_Process_GetAppQEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_M_Module_GetHandle: Module handle: TclModule_69F32B90_0_604387700MOD[TclModule_69F32B90_0_604387700]  (
Aug 11 15:33:16.855: //-1//AFW_:/AFW_Process_GetAppQEvent:     )
Aug 11 15:33:16.855: //-1//AFW_:/AFW_Process_GetAppQEvent:   }
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_M_TclModule_EventPreProcess:
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32B90_0_604387700 ---> TclModule_69F32B90_0_604387700
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_M_TclModule_Action:
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_TclModule_DefaultEvHandling:
Aug 11 15:33:16.855: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_session_indication[198])---[sess]------
Aug 11 15:33:16.855: //-1//TCL :EE69285A18000:/tcl_LegObjCmd:  leg setup 202 callInfo
Aug 11 15:33:16.855: //-1//CSPK:EE69285A18000:/tcl_LegSetupObjCmd: leg setup 202 callInfo
Aug 11 15:33:16.859: //-1//CSPK:/tclSetControlParams: rerouteMode(5) = NONE
Aug 11 15:33:16.859: //-1//CSPK:EE69285A18000:/C_CallSetup_Start: ControlInfo = 0x69EE0C30, callInfo = 0x69F484D4, destination[0]=202
Aug 11 15:33:16.859: //-1//CSPK:EE69285A18000:/C_CallSetup_Start: configured mode=rotary (1)
Aug 11 15:33:16.859: //-1//Call:/AFW_CallSetup_New:
Aug 11 15:33:16.859: //-1//AFW_:/AFW_FSM_New:
Aug 11 15:33:16.859: //-1//AFW_:LP:EE69285A18000:HN2406397C:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 0
Aug 11 15:33:16.859: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
Aug 11 15:33:16.859: //-1//AFW_:EE69285A18000:/AFW_Object_AddListener: adding Module TclModule as listener
Aug 11 15:33:16.859: //-1//AFW_:EE69285A18000:/AFW_M_Module_GetHandle: Module handle: CallSetup_69149850_0_604387708
Aug 11 15:33:16.859: //-1//Call:EE69285A18000:/AFW_CallSetup_AddDest:  202 index 0
Aug 11 15:33:16.859: //-1//Call:EE69285A18000:/AFW_M_CallSetup_Initiate:
Aug 11 15:33:16.859: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
Aug 11 15:33:16.863: //-1//Call:EE69285A18000:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
Aug 11 15:33:16.863: //-1//Call:EE69285A18000:/CallSetupInitiate:
Aug 11 15:33:16.863: //-1//Call:EE69285A18000:/CS_Placecall:
Aug 11 15:33:16.863: //-1//Call:EE69285A18000:/CS_Placecall: enable reroute_ind intercept for reroutemode NONE
Aug 11 15:33:16.863: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
Aug 11 15:33:16.863: //-1//Dest:/AFW_Destination_New:
Aug 11 15:33:16.863: //-1//AFW_:/AFW_FSM_New:
Aug 11 15:33:16.863: //-1//AFW_:LP:EE69285A18000:HN24063980:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
Aug 11 15:33:16.863: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
Aug 11 15:33:16.863: //-1//AFW_:EE69285A18000:/AFW_Object_AddListener: adding Module CallSetup as listener
Aug 11 15:33:16.863: //-1//AFW_:EE69285A18000:/AFW_M_Module_GetHandle: Module handle: Destination_6917FADC_0_604387712
Aug 11 15:33:16.863: //-1//Dest:EE69285A18000:/AFW_Destination_AddDest:
Aug 11 15:33:16.863: //-1//Dest:/AFW_Destination_AddDest: adding destination "202"
Aug 11 15:33:16.863: //-1//Dest:EE69285A18000:/AFW_M_Destination_Initiate:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/AFW_M_Destination_Initiate: Outgoing guid : 5B79869D.3F6411E5.89FBC175.851B1C9E
Aug 11 15:33:16.867:  Incoming_guid : 00000000.00000000.00000000.00000000
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/AFW_M_Destination_Initiate: Outgoing gcid : 00000000.00000000.00000000.00000000
Aug 11 15:33:16.867:  Incoming_gcid : 00000000.00000000.00000000.00000000
Aug 11 15:33:16.867: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestSetupInitiate:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestAddRerouteSetupInfo:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestAddTransferSetupInfo:
Aug 11 15:33:16.867: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 202
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestMatchDialPeer:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestMatchDialPeer: src carrier id:, tgt carrier id:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestQueuePeers: Matched peers:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestPeerItemUpdatePreemptInfo:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestPeerItemResetLPCORInfo:
Aug 11 15:33:16.867: //-1//Dest:/DestQueuePeers:  200
Aug 11 15:33:16.867: //-1//Dest:/DestQueuePeers: , Total(1)
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestDialPeerRotary:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestOutboundCallUsingPeer: dest(202), numexpDest(202), numDestDigits(2)
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestOutboundCallUsingPeer:    prefix(.55), peer tag(200)
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestUpdatePreemptSetupInfo:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestDialPeerFilter:
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestDialPeerFilter: Checking peer [200]
Aug 11 15:33:16.867: //-1//Dest:EE69285A18000:/DestPeerFilterRouteCode: Route Code not available in callInfo
Aug 11 15:33:16.867: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(200) calling[] called[202]
Aug 11 15:33:16.871: //-1//Dest:EE69285A18000:/DestCheckTeleUnassBusy:
Aug 11 15:33:16.871: //-1//Dest:EE69285A18000:/DestHandleLPCOR:
Aug 11 15:33:16.871: //-1//Dest:EE69285A18000:/DestSetup:
Aug 11 15:33:16.871: //-1//AFW_:/AFW_Leg_GetTypeDetail:  ***ERROR*** pLeg is NULL
Aug 11 15:33:16.871: //-1//AFW_:/AFW_Util_SaveRawMsg:
Aug 11 15:33:16.871: //-1//AFW_:/AFW_Leg_New:
Aug 11 15:33:16.871: //1419/5B79869D89FB/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
Aug 11 15:33:16.871: //1419/5B79869D89FB/AFW_:/AFW_M_Leg_SetExecEnv:
Aug 11 15:33:16.871: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
Aug 11 15:33:16.871: //-1/5B79869D89FB/AFW_:LP:EE69285A18000:LG1419:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 3
Aug 11 15:33:16.871: //1419/5B79869D89FB/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
Aug 11 15:33:16.871: //1419/5B79869D89FB/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_1419
Aug 11 15:33:16.871: //1419/5B79869D89FB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 17A type 3
Aug 11 15:33:16.871: //-1//Dest:EE69285A18000:/DestSetup: Destination setup success
Aug 11 15:33:16.871: //-1//Dest:EE69285A18000:/AFW_M_Destination_Initiate: attempting call to destination 202
Aug 11 15:33:16.871: //-1//Call:EE69285A18000:/CS_Placecall: Call placed to 202 index 0
Aug 11 15:33:16.875: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(I[1])---------------
Aug 11 15:33:16.875: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32B90_0_604387700 ---> TclModule_69F32B90_0_604387700
Aug 11 15:33:16.875: //-1//AFW_:EE69285A18000:/AFW_M_Event_Free:
Aug 11 15:33:16.875: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 11 15:33:16.875: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:16.875: //-1//AFW_:/AFW_M_Event_Free:
Aug 11 15:33:16.875: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 11 15:33:16.883: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 11 15:33:16.883: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
Aug 11 15:33:16.883: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:16.883: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1419][LEG_OUTINIT(7)][Cause(0)]
Aug 11 15:33:16.883: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 11 15:33:16.883: //1419/5B79869D89FB/SSIN:/AFW_SS_MapEvent:
Aug 11 15:33:16.883: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1419   ][LEG_OUTINIT(7)][Cause(0)]
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners:
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:16.883: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:16.883: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1419][LEG_OUTINIT(7)][Cause(0)]
Aug 11 15:33:16.883: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:16.883: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 11 15:33:16.883: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32B90_0_604387700 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.883: //-1//Dest:EE69285A18000:/AFW_M_Destination_Action:
Aug 11 15:33:16.883: //-1//Dest:EE69285A18000:/AFW_Destination_Action:
Aug 11 15:33:16.883: //-1//Dest:EE69285A18000:/OB_FSM_Drive:
Aug 11 15:33:16.887: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.887: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
Aug 11 15:33:16.887: //-1//Dest:EE69285A18000:/OB_Setting_Proceeding:
Aug 11 15:33:16.887: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 11 15:33:16.887: //-1//Dest:EE69285A18000:/IW_FSM_Drive:
Aug 11 15:33:16.887: //-1//Dest:EE69285A18000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 11 15:33:16.887: //-1//Dest:EE69285A18000:/DestIsEventNotified:
Aug 11 15:33:16.887: //-1//Dest:EE69285A18000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 11 15:33:16.887: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> TclModule_69F32B90_0_604387700
Aug 11 15:33:16.887: //1419/5B79869D89FB/AFW_:/AFW_M_Event_Free:
Aug 11 15:33:16.887: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 11 15:33:16.887: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK2DF22FE
Date: Tue, 11 Aug 2015 13:33:16 GMT
Call-ID: 5B7BF73D-3F6411E5-89FEC175-851B1C9E@10.160.3.56
Min-SE:  1800
Cisco-Guid: 1534690973-1063522789-2314977653-2233146526
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1439299996
Expires: 180
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 1332 3154 IN IP4 10.160.3.56
s=SIP Call
t=0 0
m=audio 17184 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 11 15:33:16.899: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <sip:202@10.160.3.55>;tag=23D53B80-1BA6
CSeq: 101 INVITE
Content-Length: 0
Aug 11 15:33:16.907: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:16.907: //1419/5B79869D89FB/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 11 15:33:16.907: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_FEATURE(38)] {
Aug 11 15:33:16.907: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:16.907: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1419][LEG_OUTPROCEED(8)][Cause(0)]
Aug 11 15:33:16.907: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 11 15:33:16.907: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
Aug 11 15:33:16.907: //1419/5B79869D89FB/AFW_:/AFW_M_Leg_EventPreProcess: LEG[1419   ][LEG_OUTPROCEED(8)][Cause(0)]
Aug 11 15:33:16.907: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners:
Aug 11 15:33:16.907: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:16.907: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:16.907: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1419][LEG_OUTPROCEED(8)][Cause(0)]
Aug 11 15:33:16.911: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 11 15:33:16.911: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:16.911: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/AFW_M_Destination_Action:
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/AFW_Destination_Action:
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/OB_FSM_Drive:
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_feature[38])---[C_Action]------
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/OB_Ignore: IGNORING EVENT
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/IW_FSM_Drive:
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/DestIsEventNotified:
Aug 11 15:33:16.911: //-1//Dest:EE69285A18000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> NULL
Aug 11 15:33:16.911: //1419/5B79869D89FB/AFW_:/AFW_M_Event_Free:
Aug 11 15:33:16.911: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 11 15:33:16.915: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK2E01CA6
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 268
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Aug 11 15:33:16.931: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <sip:202@10.160.3.55>;tag=23D53BA0-26A1
CSeq: 102 INVITE
Require: 100rel
RSeq: 3218
Content-Length: 0
Aug 11 15:33:16.935: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:16.935: //1419/5B79869D89FB/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 11 15:33:16.935: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_ALERT(16)] {
Aug 11 15:33:16.935: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:16.935: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1419][LEG_OUTPROCEED(8)][Cause(0)]
Aug 11 15:33:16.935: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 11 15:33:16.935: //1419/5B79869D89FB/SSIN:/AFW_SS_MapEvent:
Aug 11 15:33:16.935: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners:
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:16.939: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:16.939: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1419][LEG_OUTPROCEED(8)][Cause(0)]
Aug 11 15:33:16.939: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 11 15:33:16.939: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.939: //-1//Dest:EE69285A18000:/AFW_M_Destination_Action:
Aug 11 15:33:16.939: //-1//Dest:EE69285A18000:/AFW_Destination_Action:
Aug 11 15:33:16.939: //-1//Dest:EE69285A18000:/OB_FSM_Drive:
Aug 11 15:33:16.939: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.939: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_alert[16])---[C_Action]------
Aug 11 15:33:16.939: //-1//Dest:EE69285A18000:/OB_Setting_Alert:
Aug 11 15:33:16.939: //-1//Dest:/OB_Setting_Alert: aData bitmask 0x80000001
Aug 11 15:33:16.939: //-1//Dest:/OB_Setting_Alert: aData.display_info=Ext. twozerothree
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 11 15:33:16.939: //1419/5B79869D89FB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 11 15:33:16.939: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
Aug 11 15:33:16.943: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:16.943: //-1//Dest:EE69285A18000:/IW_FSM_Drive:
Aug 11 15:33:16.943: //-1//Dest:EE69285A18000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 11 15:33:16.943: //-1//Dest:EE69285A18000:/DestIsEventNotified:
Aug 11 15:33:16.943: //-1//Dest:EE69285A18000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
Aug 11 15:33:16.943: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> NULL
Aug 11 15:33:16.943: //1419/5B79869D89FB/AFW_:/AFW_M_Event_Free:
Aug 11 15:33:16.943: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 11 15:33:16.943: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK2E12153
CSeq: 103 PRACK
RAck: 3218 102 INVITE
Max-Forwards: 70
Content-Length: 0
Aug 11 15:33:16.947: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Aug 11 15:33:19.383: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 3438 6464 IN IP4 10.160.3.55
s=SIP Call
t=0 0
m=audio 18124 RTP/AVP 0 19 101
a=rtpmap:19 CN/8000
a=fmtp:101 0-16
a=ptime:20
Aug 11 15:33:19.391: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:19.391: //1419/5B79869D89FB/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 11 15:33:19.391: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_CONNECTED(17)] {
Aug 11 15:33:19.391: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:19.391: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1419][LEG_OUTRINGING(9)][Cause(0)]
Aug 11 15:33:19.391: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 11 15:33:19.391: //1419/5B79869D89FB/SSIN:/AFW_SS_MapEvent:
Aug 11 15:33:19.391: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 11 15:33:19.391: //1419/5B79869D89FB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 17A type 1
Aug 11 15:33:19.391: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners:
Aug 11 15:33:19.395: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:19.395: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:19.395: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1419][LEG_OUTCONNECTED(10)][Cause(0)]
Aug 11 15:33:19.395: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 11 15:33:19.395: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:19.395: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
Aug 11 15:33:19.395: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_6917FADC_0_604387712
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/AFW_M_Destination_Action:
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/AFW_Destination_Action:
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/OB_FSM_Drive:
Aug 11 15:33:19.395: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:19.395: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_connected[17])---[C_Action]------
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/OB_Setting_Connect:
Aug 11 15:33:19.395: //-1//Dest:/OB_Setting_Connect: cData.display_info=Ext. twozerothree
Aug 11 15:33:19.395: //1419/5B79869D89FB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 11 15:33:19.395: //1419/5B79869D89FB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =203,notifyData.display_info = Ext. twozerothree,notifyData.connected_num.oct3a = 0
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/DestNotifySharedLnState: callid: 1419, peer: 200
Aug 11 15:33:19.395: //-1//Dest:EE69285A18000:/DestNotifySharedLnState: Shared-Line NOT enabled!
Aug 11 15:33:19.395: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> Destination_6917FADC_0_604387712
Aug 11 15:33:19.399: //-1//Dest:EE69285A18000:/IW_FSM_Drive:
Aug 11 15:33:19.399: //-1//Dest:EE69285A18000:/IW_FSM_Drive: No interworking leg, no need to interwork event
Aug 11 15:33:19.399: //-1//Dest:EE69285A18000:/DestIsEventNotified:
Aug 11 15:33:19.399: //-1//Dest:EE69285A18000:/DestComplete: peer #:200 IW State IW_STATE_INIT, OB State OB_STATE_DONE
Aug 11 15:33:19.399: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_Module_ReturnArgEv:
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[1419   ][LEG_OUTCONNECTED(10)][Cause(0)]}
Aug 11 15:33:19.399: //1419/5B79869D89FB/AFW_:/AFW_Object_RemoveListener:
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_Module_UnListen:  NumObjects: 0
Aug 11 15:33:19.399: //-1//Dest:EE69285A18000:/DestReturn: Destination Returning(ds_000 Status DEST_ACTIVE)
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: Destination_6917FADC_0_604387712 ---> NULL
Aug 11 15:33:19.399: //1419/5B79869D89FB/AFW_:/AFW_M_Event_Free:
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 11 15:33:19.399: //-1//AFW_:EE69285A18000:/AFW_Process_GetPriorityQEvent: Received
Aug 11 15:33:19.399: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(221)] {
Aug 11 15:33:19.399: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:19.399: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:19.399: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
Aug 11 15:33:19.403: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
Aug 11 15:33:19.403: //-1//Dest:EE69285A18000:/AFW_M_Destination_EventPreProcess:
Aug 11 15:33:19.403: //1419/5B79869D89FB/Dest:/DestUpdateSuccessStats:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Object_WalkListeners:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:19.403: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_69149850_0_604387708]  (
Aug 11 15:33:19.403: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_6917FADC_0_604387712]  (
Aug 11 15:33:19.403: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Object_WalkListeners: Entering Module : CallSetup
Aug 11 15:33:19.403: //1419/5B79869D89FB/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Object_RemoveListener:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Module_UnListen:  NumObjects: 1
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_69149850_0_604387708
Aug 11 15:33:19.403: //-1//Call:EE69285A18000:/AFW_M_CallSetup_Action:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[221])---[C_Action]------
Aug 11 15:33:19.403: //-1//Call:EE69285A18000:/CS_Placecall_DestDone:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
Aug 11 15:33:19.403: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Module_ReturnArgEv:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[1419   ][LEG_OUTCONNECTED(10)][Cause(0)]}
Aug 11 15:33:19.403: //1419/5B79869D89FB/AFW_:/AFW_Object_RemoveListener:
Aug 11 15:33:19.403: //-1//AFW_:EE69285A18000:/AFW_Module_UnListen:  NumObjects: 0
Aug 11 15:33:19.403: //-1//Call:EE69285A18000:/CS_Complete: CallSetup Returning(ls_000 Status CS_ACTIVE)
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: CallSetup_69149850_0_604387708 ---> NULL
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_Object_WalkListeners:
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_M_Event_Free:
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_6917FADC_0_604387712
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_Object_RemoveAllListener:
Aug 11 15:33:19.407: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 3
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 2
Aug 11 15:33:19.407: //-1//AFW_:HN24063980:/AFW_M_Event_Free: ExecEnv objCount: 3
Aug 11 15:33:19.407: //-1//Dest:HN24063980:/AFW_M_Destination_Free:
Aug 11 15:33:19.407: //-1//Dest:HN24063980:/DestEmptyPreemptHoldQ:
Aug 11 15:33:19.407: //-1//AFW_:/AFW_M_FSM_Free:
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
Aug 11 15:33:19.407: //-1//AFW_:EE69285A18000:/AFW_Process_GetPriorityQEvent: Received
Aug 11 15:33:19.407: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(219)] {
Aug 11 15:33:19.407: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:19.407: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_69149850_0_604387708]  (
Aug 11 15:33:19.407: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
Aug 11 15:33:19.407: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
Aug 11 15:33:19.407: //-1//Call:EE69285A18000:/AFW_M_CallSetup_EventPreProcess:
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:19.411: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_69F32B90_0_604387700]  (
Aug 11 15:33:19.411: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_69149850_0_604387708]  (
Aug 11 15:33:19.411: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_Object_WalkListeners: Entering Module : TclModule
Aug 11 15:33:19.411: //1419/5B79869D89FB/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_Object_RemoveListener:
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_Module_UnListen:  NumObjects: 1
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_69F32B90_0_604387700
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_M_TclModule_Action:
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_TclModule_DefaultEvHandling:
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [1419]'s session
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION BEGIN: ------(I[1],ev_setup_done[219])---[setupDone]------
Aug 11 15:33:19.411: //-1//TCL :EE69285A18000:/tcl_InfotagObjCmd:  infotag get evt_status
Aug 11 15:33:19.411: //-1//TCL :EE69285A18000:/tcl_InfotagGetObjCmd: infotag get evt_status
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/vtr_ev_status: argc 2 argindex 2
Aug 11 15:33:19.411: //-1//TCL :EE69285A18000:/tcl_PutsObjCmd: ls_000
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: ACTION END: -------------(I[1])---------------
Aug 11 15:33:19.411: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32B90_0_604387700 ---> NULL
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_M_Event_Free:
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_69149850_0_604387708
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_Object_RemoveAllListener:
Aug 11 15:33:19.415: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 2, CmdPending 2
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 1
Aug 11 15:33:19.415: //-1//AFW_:HN2406397C:/AFW_M_Event_Free: ExecEnv objCount: 2
Aug 11 15:33:19.415: //-1//Call:HN2406397C:/AFW_M_CallSetup_Free:
Aug 11 15:33:19.415: //-1//AFW_:/AFW_M_FSM_Free:
Aug 11 15:33:19.415: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
Aug 11 15:33:19.415: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:19.415: //-1//AFW_:/AFW_M_Event_Free:
Aug 11 15:33:19.415: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 11 15:33:19.415: //1419/5B79869D89FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.160.3.56:5060;branch=z9hG4bK2E21420
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Aug 11 15:33:19.419: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:19.419: //-1//AFW_:/AFW_M_Event_Free:
Aug 11 15:33:19.419: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
Aug 11 15:33:22.403: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:10.160.3.56:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.3.55:5060;branch=z9hG4bK40B6F8
To: <sip:10.160.3.56>;tag=240639A8-AAF
Date: Tue, 11 Aug 2015 13:33:19 GMT
Max-Forwards: 70
Timestamp: 1439300002
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=140,OS=22400,PR=0,OR=0,PL=0,JI=0,LA=0,DU=3
Content-Length: 0
Aug 11 15:33:22.407: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
Aug 11 15:33:22.407: //1419/5B79869D89FB/AFW_:/AFW_Process_GetCcqEvent: Received
Aug 11 15:33:22.407: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECTED(20)] {
Aug 11 15:33:22.407: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x69285A18][test]
Aug 11 15:33:22.407: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[1419][LEG_OUTCONNECTED(10)][Cause(0)]
Aug 11 15:33:22.407: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
Aug 11 15:33:22.407: //1419/5B79869D89FB/SSIN:/AFW_SS_MapEvent:
Aug 11 15:33:22.407: //-1//SSIN:/AFW_SS_SIP_MapEvent:
Aug 11 15:33:22.407: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners:
Aug 11 15:33:22.407: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: START
Aug 11 15:33:22.407: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_69F32B90_0_604387700]  (
Aug 11 15:33:22.407: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[1419][LEG_OUTCONNECTED(10)][Cause(16)]
Aug 11 15:33:22.411: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
Aug 11 15:33:22.411: //1419/5B79869D89FB/AFW_:/AFW_M_Object_ShowListeners: END
Aug 11 15:33:22.411: //1419/5B79869D89FB/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_69F32B90_0_604387700
BWS-2801#
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_M_TclModule_Action:
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_TclModule_DefaultEvHandling:
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_FSM_Drive: FSM no match for (I[1],ev_disconnected[20])
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_SetModuleScope: TclModule_69F32B90_0_604387700 ---> NULL
Aug 11 15:33:22.411: //1419/5B79869D89FB/AFW_:/AFW_M_Event_Free:
Aug 11 15:33:22.411: //-1//AFW_:EE69285A18000:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
Aug 11 15:33:22.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
Aug 11 15:33:23.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
Timestamp: 1439300003
CSeq: 101 BYE
Content-Length: 0
how did you do call forward, is your destination phone is IP phone?.
Raghavendra
Yes another IP phone. You can see below.
Can you test with latest version of 15.1(4) ? The one you are using has been deferred.
Received:
CSeq: 101 INVITE
Content-Length: 0
Could you please explain about your call flow what you are trying.
Raghavendra
As explained before: Script calls a remote CME ephone that has set call forward.
Raised Bug (CSCuw11988) for this issue.
Raghavendra
