CSCvp10132 - AnyConnect connections fail with TCP connection limit exceeded error
Issue is not fixed in 9.8.4.8 unfortunately.
Yes, I can confirm that this bug is not fixed in 9.8(4.8). Recommend to use 9.9(2)52.
Brett Lykins
I’m not seeing the same log messages and low conn count problem on 9.8(4)8, have you confirmed with TAC that this is the bug you’re hitting?
I'm curious if there’s a similar/related bug, but not exactly CSCvp10132.
-Brett Lykins
#ciscochampion
I am on 9.8(4)8 and this bug isn't resolved here. I was suggested by TAC to go for 9.9
