10-20-2023 06:14 AM
Hi all,
I got an email regarding this vulnerability and found CCMP as affected product.
Unfortunately in Bug description there is no detailed version mentioned.
12.6(1)ES9 has been released in august as latest release but the Bug is listed as "fixed".
Does anybody have additional information regarding this or should I better open a TAC Case to get an answer?
Dennis
Solved! Go to Solution.
10-20-2023 08:16 AM
The fix for this issue is on Microsoft side to install the patch or the workaround in the following link. I just opened a TAC & got the confirmation.
https://msrc.microsoft.com/update-guide/vulnerability/CVE-2023-44487
Dhillip A
10-20-2023 08:16 AM
Dhillip A
