Embedded switch not connecting to CBD
austin-martinez
I have a CBS 350-8FP-2G that is running the current firmware of 3.5.0.24. I am trying to get the embedded probe to connect to our current up to date CBD server. Based on the switch, the probe version is 2.9. When trying to connect to CBD, it gives me an error stating "Certificate is not yet valid". I have another switch on a different network for this same company that is able to connect to CBD without issue. I have confirmed that the problem switch has a valid static gateway, and valid DNS server. I can also confirm the switch can resolve and communicate with the hostname that I am using for communicating with the CBD server.
@austin-martinez
 If your CBD uses self-signed certificate you need to import the certificate into the CBS350
This video can help you
https://www.youtube.com/watch?v=gkAC6BvSJWk
Mark Fang
Could you please verify if the clock on the switch is set to the correct time?
