Application Policy / QoS for Wireless - DNA-Center & C9800
merilcerpos
hello everyone, i configured QoS via Policy Application Policy. When deploying this to C9800 WLC with IP 10.1.2.3 the settings i receive following error message:
NCAS10412: Wireless profile policy was not found for the device 10.1.2.3 and SSID Test
Configure Policies - Application Policies
configured as in here selecting wireless and the corresponding SSID Test: https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-3/user_guide/b_cisco_dna_center_ug_2_2_3/b_cisco_dna_center_ug_2_2_3_chapter_01100.html#id_51875
i didn't find further information for this error code. Also i double checked the wireless SSID exists, also in network settings as well as in network profile, so i don't know which wireless profile policy is meant.
Preston Chilcote
What version of DNA?
Are you able to Edit the relevant wireless profile?  If not, you may be hitting
CSCwb28127- "Edit" button doesn't work on one of the wireless profiles
Which could also be linked to the error you saw.  Perhaps if you delete the wireless profile and start over, that could be a workaround.
