05-19-2022 01:30 AM
Hi Folks,
In the past, I've used WLC with DNA-C for SD-A implementations. And as far as I can see and know from the configuration we have to configure a WLC to a specific site only to deploy any configuration and this is a limitation.
We have a single WLC which is used over the top for a number of branches. Is there any way I can assign the WLC for multiple sites or is there no way to get around this - Note: We are NOT using SD-A here - The goal is to add the WLC for assurance/telemetry purposes but it would be nice to assign the APs to the different sites and import the floor maps we have.
Jon
05-19-2022 01:45 AM
When you say Multiple site, SD-A or non SD-A deployment, If i understand collectly Tradtional OTT deployment you can do right with remote side with Central WLC ? what is the issue here ( or am i misundertanding your requirement ?)
05-19-2022 04:20 AM
Not possible, at least in the current versions. When you add the WLC on the DNAC for Assurance/Telemetry, you need to assign it to a site otherwise will not work.
05-19-2022 08:13 AM
Ideally, you should assign your WLC to the building/floor it is physically located. When you provision the WLC, you will have the opportunity to specify the 'Primary & Secondary AP Managed locations' for that wireless LAN controller. You can select any floor(s) for the branch locations as a AP managed location for that WLC which basically tells the DNAC that the WLC will manage access points assigned to those floors.
05-20-2022 01:33 AM
Thanks guys - i thought this was the case but good to confirm with you all.
