Bridge VLAN and Sub-interface in Cisco Catalyst 9500
Eng.AD27
Hello dear
I need your support to know if i can to bridge L2 VLAN with L2 Sub-interface in the same device C9500-48Y4C
to pass the service through this  VLAN
balaji.bandi
what is the use case here, can you give some example what you looking achieve? (there may be other way around to fix the issue depends on the requirement)
check the guide lines and limitation of bridging :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-6/configuration_guide/vlan/b_176_vlan_9500_cg/configuring_layer_3_subinterfaces.html
check some new added on 17.13 :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-13/configuration_guide/lyr2/b_1713_lyr2_9500_cg/configuring_ieee_802_1q_tunneling.html
BB
my device B is connected to Customer Devices A and C ... B connected with A through portswitch port type ( trunk )
B connected with C through no switchport port type (Sub-interfaces)
now how can i pass any VLAN from A to C through B ?
You will need to convert the routed port to a switched port. I don't believe that there is any (sensible) way to achieve L2 bridging through a L3 interface.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
