C9500-40X ERPSAN and local SPAN: use of same source ports possible?
moritz.orphall
C9500-40X: ERPSAN and SPAN: can a configured ERSPAN source session have overlapping sourde ports with a local SPAN session?
Best Regards!
Edson A. Hernandez
Yes, you can configure the same source interface in many sessions without overlapping, the only restriction is with the destination, that can only be assigned to a single session
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-9/configuration_guide/nmgmt/b_179_nmgmt_9500_cg/configuring_span_and_rspan.html
**Remember to support with a like to keep the community active***
**Please, if the information was helpful, mark this answer as correct.***
Thanks for your answer. The document refers to overlapping source ports combining SPAN and RSPAN (L2 Barrier) --> in my case i would probably need to configure local SPAN and ERSPAN (L3 Barrier) together.
