C9800 Embedded WLC (9500 switch) Discovery in DNA-c
Hello all,
I am having issues provisioning WLC in my fabric, I have several questions :
  • So, I installed the 9800 embedded WLC on the 9500 , everything went well for that, I activated the WLC Role in the fabric so I see C | B | W on my border node in the fabric, but when I go to discovery and try to discover the WLC it only finds the 9500 and not the WLC that resides on it, is that normal ?
  • Should an embedded WLC be discovered that way too or is it working without discovery ?
  • Also is it normal that the WMI (wireless management interface) on the WLC is the same IP as the loopback 0 of the switch ?
  • Option 43 for AP's should point to WMI IP ?
Thanks in advance for helping.
Adel Iazzag
balaji.bandi
DNAC support Fabric in BOX
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html#FIAB_Site_Reference
Does the Cat 9500 also have different Roles ? what part of network is this Cat 9500 resides ?
BB
Hello Balaji,
This is not fabric in a box setup but full fabric for small site :
The 9500 is the one I circled in green, it's BN, CP and WLC. but in discovery it just finds the switch not the router, Netconf and everything is OK , look at the discovery window here :
I wan't to know how to provision the WLC (if I need to) for AP's to be able to register with it.
Adel Iazzag
As per i know that is not supported as per your diagram, i am also part of the same journey, wait for some one to confirm that.
BB
What do you mean not supported ? Can you develop please ?
Thanks.
Adel Iazzag
