Cat Center Question using Interactive Commands
econstas
Hello, I'm attempting to execute my first interactive command but it's consistently failing. I've tried various approaches, but I'm still stuck. Any advice would be greatly appreciated.
#INTERACTIVE
authentication convert-to new-style <IQ> Do you wish to continue? [yes]: <R>y
#END_INTERACTIVE
Manually adding the config statement:
Labswitch12345(config)#authentication convert-to new-style
This operation will permanently convert all relevant authentication commands to their CPL control-policy equivalents. As this conversion is irreversible and will disable the conversion CLI 'authentication display [legacy|new-style]', you are strongly advised to back up your current configuration before proceeding.
Do you wish to continue? [yes]: no
Failure Message:
Message: Unable to push the invalid CLI to the device 10.x.x.x using protocol telnet. Invalid CLI -  Current output :
Current expects : Labswitch1.{0,30}([^)]+)#s*z (Config Prompt)
Labswitch12345#s*z (Prompt)
 Do you wish to continue? [yes]:   (Interactive)
 I
Torbjørn
I think it might not be matching the prompt for verification correctly. Can you try this instead?
authentication convert-to new-style<IQ>yes<R>no
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
econstas
Thank you. It worked. Appreciate your assistance.
