Catalyst Center schedule SSID availability per site.
pielunswe
Hi!
We would like to turn of specific SSID per site. We have about 700 sites and would like turn off the common Guestportal SSID for some of the sites in the night. Is this possible in any upcoming version of CatC?
7 Replies 7
Torbjørn
I think the easiest way to achieve this is to create a time condition for your ISE policy. See this post for how to achieve this: https://community.cisco.com/t5/network-access-control/cisco-ise-time-based-authorization/td-p/4623155
I might be wrong, but I don't think there is an elegant way to achieve only for specific sites on the Cat-C with the regular "scheduling" options in C9800 network profiles.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Nice! 2.3.7 is packed with useful new features. I just hope a 2.3.7.X release becomes the recommended version soon.
Hi!
Yes, but seems its for the entire ssid? not the ssid at specific locations. Thanks for the info, I'll check it!
Leo Laohoo
What firmware is the WLC on?
There is a Calendar feature since 17.12.X.  It is crude but it will work.
Alternatively, create an EEM script coupled with KRON can also be an alternative.
The 9800's are running 17.12.4 with the available apsp. I'll check the docmenation for calendar feature. thanks
