Catalyst Center - Set in order template in mode provisioning device
LAN team
When a device is provisioned by CatalystCenter, several user defined template are pushed to device.
But I'm not able to choose or to understand in what order these several templates are pushed by DNAC to the device.
Thank for your help.
Torbjørn
Hello @LAN team,
If you need to control the order of the templates you should put them in a "composite sequence" template, this allows you to order them however you like. If you add them directly in you network profile can see the order they have been applied under the task details of the "provision" task.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
Hello @LAN team,
Yes, I can see the order they have been applied once applied, but my question is how DNAC define this order, what is the logic ?
Anyway, indeed with composite sequence it's ok, thank you.
mmcpaul
I am wondering how these work as well.  When I provision a device some templates are applied automatically while others require a tag to be applied.  Can someone please explain this?  Thanks.
