Intermittent Connection Issues
edusccc333
We recently upgraded our Wi-Fi system from 8 ASUS routers to Cisco C9105AX APs, and we initially set up a single SSID for all APs. However, too many students connecting to the same SSID caused significant slowdowns, so we divided SSIDs per AP. This helped improve performance significantly, but we are still experiencing persistent but unpredictable issues where some students randomly experience slow speeds or disconnections.
  • The previous ASUS router setup had no issues.
  • The problem only started after switching to the Cisco C9105AX APs.
  • Using a single SSID caused network slowdowns, so we separated SSIDs per AP, which improved performance.
  • However, intermittent disconnection and slow speed issues persist.
  • The issue occurs randomly among students and is not linked to a specific time or device.
  • Most students use the latest tablets or iPads.
  • Since the issue is not consistently reproducible, troubleshooting is difficult.
What settings should I adjust to further optimize performance? Are there specific logs or configurations I should focus on?
Any insights would be greatly appreciated.
Below is information about the APs
#show ap dot11 5ghz summary
* global assignment
AP Name Mac Address Slot Admin State Oper State Width Txpwr Channel Mode
AP-2 4800.b3b3.26e0 1 Enabled Up 40 1/8 (20 dBm) (149,153) REAP
AP-10 4800.b3b6.7fe0 1 Enabled Up 40 1/8 (20 dBm) (44,48) REAP
AP-8 4800.b3b6.80a0 1 Enabled Up 40 1/8 (20 dBm) (44,48) REAP
AP-4 4800.b3b6.8ba0 1 Enabled Up 40 1/8 (20 dBm) (40,36) REAP
AP-11 4800.b3b6.8cc0 1 Enabled Up 40 1/8 (20 dBm) (149,153) REAP
AP-7 4800.b3b6.9a20 1 Enabled Up 40 1/8 (20 dBm) (161,157) REAP
AP-6 4800.b3b6.9c00 1 Enabled Up 40 1/8 (20 dBm) (157,161) REAP
AP-3 4800.b3b6.b420 1 Enabled Up 40 1/8 (20 dBm) (157,161) REAP
AP-12 4800.b3b6.d500 1 Enabled Up 40 1/8 (20 dBm) (36,40) REAP
AP-9 4800.b3b6.e1a0 1 Enabled Up 40 1/8 (20 dBm) (40,36) REAP
AP-1 4800.b3b6.e340 1 Enabled Up 40 1/8 (20 dBm) (36,40) REAP
AP-5 4800.b3b8.b1c0 1 Enabled Up 40 1/8 (20 dBm) (149,153) REAP
Fri Feb 14 2025 22:19:24 GMT+0900 (한국 표준시)
#show ap dot11 24ghz summary
* global assignment
AP-2 4800.b3b3.26e0 0 Enabled Up 20 1/8 (15 dBm) (13) REAP
AP-10 4800.b3b6.7fe0 0 Enabled Up 20 1/8 (15 dBm) (9) REAP
AP-8 4800.b3b6.80a0 0 Enabled Up 20 1/8 (15 dBm) (13) REAP
AP-4 4800.b3b6.8ba0 0 Enabled Up 20 1/8 (15 dBm) (9) REAP
AP-11 4800.b3b6.8cc0 0 Enabled Up 20 1/8 (15 dBm) (13) REAP
AP-7 4800.b3b6.9a20 0 Enabled Up 20 1/8 (15 dBm) (1) REAP
AP-6 4800.b3b6.9c00 0 Enabled Up 20 1/8 (15 dBm) (5) REAP
AP-3 4800.b3b6.b420 0 Enabled Up 20 1/8 (15 dBm) (1) REAP
AP-12 4800.b3b6.d500 0 Enabled Up 20 1/8 (15 dBm) (1) REAP
AP-9 4800.b3b6.e1a0 0 Enabled Up 20 1/8 (15 dBm) (5) REAP
AP-1 4800.b3b6.e340 0 Enabled Up 20 1/8 (15 dBm) (1) REAP
AP-5 4800.b3b8.b1c0 0 Enabled Up 20 1/8 (15 dBm) (9) REAP
Cisco AP Name : AP-1
Cisco AP Identifier : 4800.b3b6.e340
Country Code : KE
Regulatory Domain Allowed by Country : 802.11bg:-ACEK 802.11a:-CK 802.11 6GHz:
AP Country Code : KE - Korea Extended (CK)
AP Regulatory Domain
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.5528
IP Address Configuration : Static IP assigned
IP Address : 192.168.110.1
IP Netmask : 255.255.255.0
Gateway IP Address : 192.168.110.99
Fallback IP Address Being Used : 0.0.0.0
Domain :
Name Server : 168.126.63.1
CAPWAP Path MTU : 1485
Capwap Active Window Size : 1
Telnet State : Disabled
CPU Type : ARMv7 Processor rev 5 (v7l)
Memory Type : DDR4
Memory Size : 1989632 KB
SSH State : Enabled
Serial Console State : Enabled
Cisco AP Location : GyoMuSil
Site Tag Name : default-site-tag
RF Tag Name : default-rf-tag
Policy Tag Name : teacher-policy-tag
AP join Profile : default-ap-profile
Flex Profile : default-flex-profile
Primary Cisco Controller Name : Not Configured
Primary Cisco Controller IP Address : 0.0.0.0
Secondary Cisco Controller Name : Not Configured
Secondary Cisco Controller IP Address : 0.0.0.0
Tertiary Cisco Controller Name : Not Configured
Tertiary Cisco Controller IP Address : 0.0.0.0
Administrative State : Enabled
Operation State : Registered
NAT External IP Address : 192.168.110.1
AP Certificate type : Manufacturer Installed Certificate
AP Certificate Expiry-time : 07/04/1963 14:30:10
AP Certificate issuer common-name : High Assurance SUDI CA
AP Certificate Policy : Default
AP CAPWAP-DTLS LSC Status
Certificate status : Not Available
AP 802.1x LSC Status
AP LSC authentication state : CAPWAP-DTLS
AP Mode : FlexConnect
AP VLAN tagging state : Disabled
AP VLAN tag : 0
CAPWAP Preferred mode : IPv4
CAPWAP UDP-Lite : Not Configured
AP Submode : Not Configured
Office Extend Mode : Disabled
Link-Encryption : Disabled
Dhcp Server : Disabled
Remote AP Debug : Disabled
Logging Trap Severity Level : information
Logging Syslog facility : kern
Software Version : 17.9.6.40
Boot Version : 1.1.2.4
Mini IOS Version : 0.0.0.0
Stats Reporting Period : 180
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
MDNS Group Method : None
PoE Pre-Standard Switch : Disabled
PoE Power Injector MAC Address : Disabled
Power Type/Mode : PoE/Full Power
Number of Slots : 2
AP Model : C9105AXI-K
IOS Version : 17.9.6.40
Reset Button : Disabled
AP Serial Number : FGL2843L1EV
Management Frame Validation : Capable
Management Frame Protection : Not capable
AP User Name : admin
AP 802.1X User Mode : Global
AP 802.1X User Name : Not Configured
Cisco AP System Logging Host : 255.255.255.255
Cisco AP Secured Logging TLS mode : Disabled
AP Up Time : 14 days 23 hours 33 minutes 32 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 24 seconds
Join Date and Time : 02/03/2025 03:10:08
Join Taken Time : 3 hours 0 minute 17 seconds
Join Priority : 1
AP Link Latency : Disable
AP Lag Configuration Status : Disabled
Lag Support for AP : No
Rogue Detection : Enabled
Rogue Containment auto-rate : Disabled
Rogue Containment of standalone flexconnect APs : Disabled
Rogue Detection Report Interval : 10
Rogue AP minimum RSSI : -90
Rogue AP minimum transient time : 0
AP TCP MSS Adjust : Enabled
AP TCP MSS Size : 1250
AP IPv6 TCP MSS Adjust : Enabled
AP IPv6 TCP MSS Size : 1250
Hyperlocation Admin Status : unknown
Retransmit count : 5
Retransmit interval : 3
Fabric status : Disabled
FIPS status : Disabled
WLANCC status : Disabled
GAS rate limit Admin status : Disabled
WPA3 Capability : Enabled
EWC-AP Capability : Enabled
AWIPS Capability : Enabled
AID Management Capability : Enabled
Proxy Hostname : Not Configured
Proxy Port : Not Configured
Proxy NO_PROXY list : Not Configured
GRPC server status : Disabled
Unencrypted Data Keep Alive : Enabled
Local DHCP Server : Disabled
Traffic Distribution Statistics Capability : Enabled
Dual DFS Statistics : Disabled
AP Upgrade Out-Of-Band Capability : Disabled
AP statistics : Disabled
AP power derate Capability : Disabled
AP PMK Propagation Capability : Enabled
Mesh DCA Run Status : N/A
Last Mesh DCA Run :
Meraki Capable AP : No
Cisco AP Name : AP-2
Cisco AP Identifier : 4800.b3b3.26e0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bc.dd9c
IP Address : 192.168.110.2
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(studycafe)
Policy Tag Name : EDUSHERPA-CAFE-TAG
NAT External IP Address : 192.168.110.2
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1EP
AP Up Time : 18 days 23 hours 32 minutes 29 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 34 seconds
Join Date and Time : 02/03/2025 03:09:58
Join Taken Time : 3 hours 0 minute 2 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-3
Cisco AP Identifier : 4800.b3b6.b420
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.4f44
IP Address : 192.168.110.3
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(C)
Policy Tag Name : EDUSHERPA-C-TAG
NAT External IP Address : 192.168.110.3
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1F3
AP Up Time : 18 days 23 hours 37 minutes 20 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 36 seconds
Join Date and Time : 02/03/2025 03:09:57
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-4
Cisco AP Identifier : 4800.b3b6.8ba0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.4a34
IP Address : 192.168.110.4
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(E1)
Policy Tag Name : EDUSHERPA-E-TAG
NAT External IP Address : 192.168.110.4
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1F9
AP Up Time : 18 days 23 hours 32 minutes 15 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 31 seconds
Join Date and Time : 02/03/2025 03:10:02
Join Taken Time : 3 hours 0 minute 8 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-5
Cisco AP Identifier : 4800.b3b8.b1c0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.8ef8
IP Address : 192.168.110.5
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(Located AP-EX Place)
Policy Tag Name : EDUSHERPA-A-TAG
NAT External IP Address : 192.168.110.5
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1ER
AP Up Time : 14 days 21 hours 44 minutes 5 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 35 seconds
Join Taken Time : 3 hours 0 minute 5 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-6
Cisco AP Identifier : 4800.b3b6.9c00
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.4c40
IP Address : 192.168.110.6
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(D2)
Policy Tag Name : EDUSHERPA-D-TAG
NAT External IP Address : 192.168.110.6
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1ET
AP Up Time : 18 days 23 hours 32 minutes 16 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 39 seconds
Join Date and Time : 02/03/2025 03:09:54
Join Taken Time : 3 hours 0 minute 6 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-7
Cisco AP Identifier : 4800.b3b6.9a20
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.4c04
IP Address : 192.168.110.7
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(D1)
NAT External IP Address : 192.168.110.7
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1F0
AP Up Time : 11 days 10 hours 13 minutes 44 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 50 seconds
Join Date and Time : 02/03/2025 03:09:44
Join Taken Time : 4 minutes 53 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-8
Cisco AP Identifier : 4800.b3b6.80a0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.48d4
IP Address : 192.168.110.8
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : BonGwan(B)
Policy Tag Name : EDUSHERPA-B-TAG
NAT External IP Address : 192.168.110.8
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1EX
AP Up Time : 18 days 23 hours 32 minutes 4 seconds
AP CAPWAP Up Time : 11 days 10 hours 8 minutes 37 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-9
Cisco AP Identifier : 4800.b3b6.e1a0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.54f4
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : ByeolGwan(S)
Policy Tag Name : EDUSHERPA-S-TAG
NAT External IP Address : 192.168.110.9
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1F8
AP Up Time : 18 days 23 hours 35 minutes 44 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-10
Cisco AP Identifier : 4800.b3b6.7fe0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.48bc
IP Address : 192.168.110.10
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : ByeolGwan(H)
Policy Tag Name : EDUSHERPA-H-TAG
NAT External IP Address : 192.168.110.10
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1EZ
AP Up Time : 18 days 23 hours 31 minutes 53 seconds
Join Date and Time : 02/03/2025 03:09:56
Join Taken Time : 3 hours 0 minute 3 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-11
Cisco AP Identifier : 4800.b3b6.8cc0
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.4a58
IP Address : 192.168.110.11
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : ByeolGwan(G)
Policy Tag Name : EDUSHERPA-G-TAG
NAT External IP Address : 192.168.110.11
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1F6
AP Up Time : 11 days 10 hours 16 minutes 6 seconds
AP CAPWAP Up Time : 11 days 10 hours 9 minutes 17 seconds
Join Date and Time : 02/03/2025 03:09:18
Join Taken Time : 6 minutes 48 seconds
Join Priority : 1
Last Mesh DCA Run :
Cisco AP Name : AP-12
Cisco AP Identifier : 4800.b3b6.d500
Country Code : KE
802.11bg : -E
802.11a : -K
MAC Address : 4800.b3bd.5360
IP Address : 192.168.110.12
Domain :
Memory Type : DDR4
SSH State : Enabled
Cisco AP Location : ByeolGwan(F)
Policy Tag Name : EDUSHERPA-F-TAG
NAT External IP Address : 192.168.110.12
AP VLAN tag : 0
LED State : Enabled
MDNS Group Id : 0
MDNS Rule Name :
Number of Slots : 2
AP Serial Number : FGL2843L1FA
AP Up Time : 18 days 23 hours 31 minutes 44 seconds
Join Date and Time : 02/03/2025 03:09:59
Join Priority : 1
Last Mesh DCA Run :
Fri Feb 14 2025 22:18:22 GMT+0900 (한국 표준시)
#show ap summary
Number of APs: 12
CC = Country Code
RD = Regulatory Domain
AP Name Slots AP Model Ethernet MAC Radio MAC CC RD IP Address State Location
AP-2 2 C9105AXI-K 4800.b3bc.dd9c 4800.b3b3.26e0 KE -K 192.168.110.2 Registered BonGwan(studycafe)
AP-10 2 C9105AXI-K 4800.b3bd.48bc 4800.b3b6.7fe0 KE -K 192.168.110.10 Registered ByeolGwan(H)
AP-8 2 C9105AXI-K 4800.b3bd.48d4 4800.b3b6.80a0 KE -K 192.168.110.8 Registered BonGwan(B)
AP-4 2 C9105AXI-K 4800.b3bd.4a34 4800.b3b6.8ba0 KE -K 192.168.110.4 Registered BonGwan(E1)
AP-11 2 C9105AXI-K 4800.b3bd.4a58 4800.b3b6.8cc0 KE -K 192.168.110.11 Registered ByeolGwan(G)
AP-7 2 C9105AXI-K 4800.b3bd.4c04 4800.b3b6.9a20 KE -K 192.168.110.7 Registered BonGwan(D1)
AP-6 2 C9105AXI-K 4800.b3bd.4c40 4800.b3b6.9c00 KE -K 192.168.110.6 Registered BonGwan(D2)
AP-3 2 C9105AXI-K 4800.b3bd.4f44 4800.b3b6.b420 KE -K 192.168.110.3 Registered BonGwan(C)
AP-12 2 C9105AXI-K 4800.b3bd.5360 4800.b3b6.d500 KE -K 192.168.110.12 Registered ByeolGwan(F)
AP-9 2 C9105AXI-K 4800.b3bd.54f4 4800.b3b6.e1a0 KE -K 192.168.110.9 Registered ByeolGwan(S)
AP-1 2 C9105AXI-K 4800.b3bd.5528 4800.b3b6.e340 KE -K 192.168.110.1 Registered GyoMuSil
AP-5 2 C9105AXI-K 4800.b3bd.8ef8 4800.b3b8.b1c0 KE -K 192.168.110.5 Registered BonGwan(Located AP-EX Place)
Preston Chilcote
It is very common to have one SSID across multiple APs, even in dense environments, with proper coverage design.  How many clients are connecting?  What was the model of ASUS router?
we used to use ac-58
Preston Chilcote
That ASUS router has external antennas so it might have had a bigger radio cell.   You would likely benefit from taking some signal strength measurements around the campus (there's a built in wireless diagnostic tool in mac os) and aiming for -70db.  The easiest solution for you may be adding more 9105's for better coverage.
There's a great Cisco Live presentation on Wifi Design.  BRKEWN-2087-  available at ciscolive.com
