Cisco 9500 Licensing
O_H
Hello, i'm not very sure of the current license status on Cisco 9500 switch and if that can affect anything on the functionality.
I see the field in show license status:
Next ACK deadline: Aug 22 08:11:36 2021 DST
And Cisco says (If an ACK is required and is not received by this deadline, a syslog is displayed.)
Here is the output of some license shows:
SW001#show license summary
License Usage:
License Entitlement Tag Count Status
network-advantage (C9500 Network Advantage) 2 IN USE
dna-advantage (C9500-16X DNA Advantage) 2 IN USE
SW001#show license status
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Last ACK received: <none>
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Aug 05 09:11:41 2021 DST
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
SW001#show license usage
License Authorization:
Status: Not Applicable
network-advantage (C9500 Network Advantage):
Description: network-advantage
Count: 2
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: network-advantage
Feature Description: network-advantage
Enforcement type: NOT ENFORCED
License type: Perpetual
dna-advantage (C9500-16X DNA Advantage):
Description: C9500-16X DNA Advantage
Count: 2
Version: 1.0
Status: IN USE
Feature Name: dna-advantage
Feature Description: C9500-16X DNA Advantage
License type: Subscription
balaji.bandi
Looks the device is registered  "License type: Perpetual"
BB
