Configure Enterprise and Management ports
Cisco1619
I am having issues getting both the enterprise and the management ports to be reachable on my DNA appliance. I put the default-gateway on the management and static routes on the enterprise and the enterprise is reachable but the management isn't. If I reverse this, the management is reachable  but the enterprise isn't. I have not been able to find a way to configure these so I can have both reachable. Does anyone have any ideas? This is a single node device running 2.2.x.x at the moment.
Thanks.
They are in different subnets. Mgmt - 10.255.155.x /24, Enterprise - 10.255.255.x /24. I tried 10.255.255.0 255.255.255.0 10.255.255.1 as my enterprise route with mgmt being default-gateway, but it didn't work. I finally put the enterprise route as 10.0.0.0 255.0.0.0 10.255.255.1. That is how it is at this moment. The enterprise is working but the mgmt isn't.
Thanks.
Dan Rowe
When you configure the static route on the enterprise port, does it overlap with the IP address/subnet configured on the MGMT port?
Thanks.
