01-27-2023 10:39 AM
I am having issues getting both the enterprise and the management ports to be reachable on my DNA appliance. I put the default-gateway on the management and static routes on the enterprise and the enterprise is reachable but the management isn't. If I reverse this, the management is reachable but the enterprise isn't. I have not been able to find a way to configure these so I can have both reachable. Does anyone have any ideas? This is a single node device running 2.2.x.x at the moment.
Thanks.
Solved! Go to Solution.
02-01-2023 01:45 PM
They are in different subnets. Mgmt - 10.255.155.x /24, Enterprise - 10.255.255.x /24. I tried 10.255.255.0 255.255.255.0 10.255.255.1 as my enterprise route with mgmt being default-gateway, but it didn't work. I finally put the enterprise route as 10.0.0.0 255.0.0.0 10.255.255.1. That is how it is at this moment. The enterprise is working but the mgmt isn't.
Thanks.
02-01-2023 01:39 PM
When you configure the static route on the enterprise port, does it overlap with the IP address/subnet configured on the MGMT port?
02-01-2023 01:45 PM
Thanks.
