Bookmark
Subscribe
473
Deploying Radius on Catalyst 3750 - Mini ISP Scenario
zhir
Dear Community,
I am using a Catalyst 3750 V2 switch and have successfully connected to the DaloRadius server. I can log into the switch with the users I created in the Radius server without any problem, Now, I want to grant or restrict access to the end users connected to the same switch. I really have no idea where to begin. Essentially, I want any user (or an AP) that is connected to this switch to have their access controlled by the Radius server, similar to how ISPs or hotels operate. Please i need a detailed guide if possible.
Thanks a lot.
Below is my current config:
*Mar 1 03:00:41.369: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
Switch>en
Switch#conf
Switch#sh run
Switch#sh running-config
Building configuration...
Current configuration : 5057 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username admin password 0 Nexus@2022
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius if-authenticated
aaa accounting exec default start-stop group radius
aaa session-id common
switch 1 provision ws-c3750v2-48ps
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 100
switchport mode access
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface FastEthernet1/0/25
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
interface Vlan100
ip address 11.11.11.13 255.255.255.0
ip access-group INTERNET-ACCESS in
ip classless
ip http server
ip http secure-server
radius-server host 11.11.11.10 auth-port 1812 acct-port 1813 key ZhirZhir@@
control-plane
line con 0
line vty 5 15
end
Switch#
Switch>en
Switch#conf
Switch#sh run
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
aaa new-model
ip subnet-zero
interface Vlan1
no ip address
interface Vlan100
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
balaji.bandi
Look  at PPPoE example guide similarly you can do on 3750 - 12.2 IOS quite old don't remember it works -  but you can try with limitations. (it required dot1.x support)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_7_e/configuration_guide/b_1527e_consolidated_2960x_cg/m_pppoe_ia.html
 PPPoE with  daloradius / freeradius example :
https://ephemeralportal.blogspot.com/2014/08/using-daloradius-in-gns3-to-demo-isps.html
BB
