02-05-2024 03:54 AM
Hello.
Can anyone please explain me what is the difference between Device Privisioning, Plug and Play and Lan Automation?
I went through some Cisco DNA Center documentations but could not get the idea of them.
What makes them different: Plug n Play, Discovery, Lan Automation
Thank You.
02-05-2024 06:29 AM
plug-and play is used to detect when a new unconfigured device is connected to your network infrastructure
the device registers itself with dna-center/catalyst-center and then you can select (day-zero) templates to send to the device
device provisioning is fine-tuning the devices configuration, by sending individual (day-n) templates to the device
day-n templates can be assigned per site / per model /per series etc
lan automation is a mechanism where no CLI connection to the device is made,
but an API programming interface is used to send query and configure commands to DNA-center,
which in turn translate this to configuration commands to the device
in the optimal situation DNA-center translates the API command to a CLI command suitable for a physical device/ IOS version
02-09-2024 12:29 AM
thanks for the info, but differences are not clear to me.
02-09-2024 01:41 AM
these are different steps in the process of configuring a network device
1) PnP is for out-of-the box/initial configuration, so that the switch gets a basic/default configuration
so it can be managed remotely and cooperate with your other network equipment
this involves software distribution and configuration using a template with commands
this template is called called day-zero template
2) provisioning is a next step to modify the configuration as needed for a specific purpose
some configuration here could also be included in the day-zero template ,
but there can be advantages to do some commands using day-N templates
you need a design how to divide configuration commands between day-zero and day-n templates
e.g. you have a basic template for ALL switches, and an extra day-n template for site-A (but not for site-B)
3) LAN automation is very broad subject,
in short it is automatically reconfiguring your network when a specific trigger occurs
(really configuration change, not only redundant routes or so)
=> if THIS happens, how do I reconfigure the network to route traffic as I want it (without manual intervention)
02-05-2024 10:23 PM
I just noticed the LAN Automation option after updating to 2.3.5.5. Will have to have a play with it
02-12-2024 02:21 AM
LAN Automation is only to automatically provision SDA devices. Where it will automatically setup a seed VLAN and port on switches, and then configure interfaces, name, and protocols for SDA on the devices, connected to those ports.
