05-08-2024 08:12 AM
Hi, anyone knows if is possible to mix Catalyst Center DN2-HW-APL with DN3-HW-APL in HA?
I didn't find any information only an short "TBD" in FAQ document about DN3 version.
Unfortunately DN2 was deployment this last year.
Thanks.
05-08-2024 08:36 AM
fist and second generation have 44 cores only
but some Gen 2 also have 56 cores, with that you can mix with Gen3 - as per my understanding.
As per i know both need to similar cores to be in cluster of HA
05-09-2024 06:08 AM
Well TBD is found in:
Yesterday I open a case in GVE for more documentation and this is the answer:
Catalyst Center currently supports two options for creating redundancy:
• A) Cluster
• B) Disaster Recovery
As of May 2024, it is not yet possible to create a mixed Catalyst Center cluster with DN2 and DN3. However, it is possible to create a mixed Disaster Recovery environment. It is expected that the implementation of Mixed Clusters can be launched by the end of 2024.
Maybe it will be possible later, I hoope so.
05-09-2024 10:51 PM
Sure that make sense, since cluster is 3 node, so Quorum need same specs as we do all the time clustering same models of specs.
DR is different case - so that is ok for different hardware.
05-10-2024 06:24 AM
Here is a screenshot from the latest version of the DN3 FAQ. I am working with the Cisco Documentation Team and this should be updated shortly in the "High Availability" documentation for 2.3.7.x.
