DNA Center on AWS
comurray
I'm deploying DNA-C on AWS for a client and am running into some issues.
Rather than connecting the AWS VPC back to an on-prem Firewall, we want to connect it to Prisma Access, so I'm setting up a Transit Gateway in AWS.
When I step through the Pod creation wizard on the DNA Portal, the option for Existing TGW is greyed out.
Anyone know why?
Has anyone deployed DNA-C on AWS successfully before?
Thx.
10 Replies 10
marce1000
   - Ref : https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/dna-center-va/aws/deploy/b_cisco_dna_center_on_aws_deployment_guide/m_deploy_using_catalyst_center_va_launchpad_1_8.html
   >....If the connection from the TGW to your on-premises firewall or router isn't connected yet, it's grayed out:
   >...If your VPC is not attached to the TGW, the TGW connection is grayed out:
 M.
Thanks M.  I think, though, you're referring to the Connection Status.  I'm referring to the choice to select "VPN GW", "New VPN GW + New TGW" or "Existing TGW", as I showed in the screenshot I attached to the original query.
Any ideas on that?
dernucooper
I work for Cisco. Its a hardware platform only. There is no official guidance on why a virtualized version is not offered but i think that Bernard_schwartz might be pretty close to why.
It has been said they are working to virtualize it, although i do not believe it will be of the same caliber as the DNAC appliance. Time will tell
Hi, did you manage to deploy ?
I was trying to deploy a demo and I'm stuck with the manual install workflow...
comurray
We were advised by TAC to use CloudFormation in AWS, as per this video https://www.youtube.com/watch?v=HT99Tsnyj_k.  That was successful.
Cisco DNA Center is finally available on AWS. Watch this video to learn about one of the two modes to deploy the Cisco DNA center on AWS - Manual Mode using Cloud Formation Template. Here are some useful links for your reference: Everything you need to know about Cisco DNA Center VA on AWS: ...
cgm
Great, thanks, manual marketplace deployment got me to a point in wich the web installer refused any configuration because of "too many IPs on an interface". Granted, I was flying blind because I found no document that stated the "correct" procedure. (web config was running on port 9004, but that was just an extrapolation of ESXi install)
Will try this. Thanks again.
cgm
Any chance you can share the CFN template ?
cgm
Too bad, I'm not buying a license to train myself, and the file is walled. Thanks anyway.
