11-06-2018 12:29 PM
Is there a way to reset a DNA Center appliance to "factory defaults" ?
Solved! Go to Solution.
11-06-2018 12:32 PM
11-06-2018 12:32 PM
11-06-2018 12:37 PM
I only want to reset the database back to "null".
Is there a downloadable ISO on CCO ? I haven´t found it.
11-06-2018 12:41 PM
11-06-2018 12:43 PM
Ok, do you know if I can find the serial for the appliance via the DNA C Gui ?
11-06-2018 12:45 PM
For Failed Backup and Restore operation requires service cleanup (Reset). I would recommend to open a TAC Case.
