DNA Center without SDA architecture or network
jaheshkhan
Level 5
Level 5
In our project, we plan to use Cisco IE4000, Cisco 9300, 9200, and possibly 9500 switches, along with Virtual DNA Center. Is it possible to utilize DNA Center without implementing an SDA network, similar to how we use Cisco Prime Infrastructure? Can we automate network operations without SDA? Will we be able to push configurations from day zero in this scenario? Additionally, can we monitor the entire network effectively?
Torbjørn
Yes, you can use Catalyst Center Assurance to monitor your network, in a similar way to what you have been doing with prime. When it comes to network automation you are able to use configuration templates and network profiles to automate device configuration. You will however need to do some work to create your network profiles before doing so.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
So we can push the configuration to zero configuration switch.
we have 400+ switches to implement.
Any cisco guide in this regard for configuration?
Preston Chilcote
@jaheshkhan
Yes, the Plug and Play feature works very well for onboarding new switches with their config.  I encourage you to ask your Cisco Account team to put you in touch with Customer Success that can help show you how to use Plug and Play.
