DNA Essentials to DNA Advantage
Jeff Horton
If I have 9300 and 9500 switches, can I upgrade from the Essentials to Advantage? If so, what are the steps in doing so?
Jeff
Yes, we don't intend customers to have to make any hardware changes in order to change licensing. Once you have the license ordered, you'll want to use the "license boot level" command and reload to enable the new license.
5 Replies 5
Jeff Horton
I think I have found the answer to my question...
C9300-LIC=
Electronic Cisco DNA Upgrade License for C9300 switches. Note: when upgrading from Cisco DNA Essentials to Cisco DNA Advantage, Network Essentials is also upgraded to Network Advantage
This allows for the upgrade to the license without having to reorder the hardware.. Does this seem correct?
Awesome thanks.
Jeff
very helpful Command
Thanks Preston
kapil.atrish
Level 4
Level 4
Commands for the Cat 9300 platform running IOS 16.X are as follows:
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9300_cg/b_166_sys_mgmt_9300_cg_chapter_011.html.xml
DNA Advantage (Single Device)
license right-to-use [activate | deactivate] addon dna-advantage subscription [acceptEULA]
license right-to-use [activate | deactivate] addon dna-advantage evaluation [acceptEULA]
DNA Advantage (Stack: all)
license right-to-use [activate | deactivate] addon dna-advantage subscription all [acceptEULA]
license right-to-use [activate | deactivate] addon dna-advantage evaluation all [acceptEULA]
tx
Kapil
