DNAC reporting
craiglebutt
Level 4
Level 4
Had DNAC for a 3 months now, running in conjunction with Prime.
Before we take prime out of the picture, need to get the reports working.
One of the main reports I need is Unique Clients and Users Summary, but this can only do 24hrs
"Unique Clients and Users Summary report only supports 24hr duration. Please choose a time range that is less than or equal to 24hrs"
Other post say DNAC reports are a straight copy and paste from Prime, is there some function not enabled?
cheers in advance
TAC have indormed me, becouse I want Client data , can only go 24hrs, so if I want a break down for a month,have to run the report 31 times for each day.
Then it only gives me the top 5, which is no good, so Prime will be staying
It seems you have until September 25. 2025 until you won't get security fixes for it. Let's hope they give us an option to expand the data retention for clients before then.  https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/prime-infrast-gen-appliance-lic-eol.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
