DNAC - Unique device report / count
chris.gruber
Is there a way in DNA Center to provide a total device count where switch stacks are not counted as 1 but as number of members.
So if I have 2 stacks of 5 members each the count would be 10, not 2.
Preston Chilcote
You can run an Inventory report and there will be a column for Serial Number that will show the number of switches in the stack.  A little bit of scripting or linux CLI magic could count those up.  It doesn't hurt for you to open a Make a Wish in the Catalyst Center Help Menu to request to make this even more straightforward.
chris.gruber
Thanks Preston,
Yeah, I can export this to Excel as well and massage the data there, but scripting and hacking CSVs to get a simple physical device count doesn't exactly scream modern, AI underpinned NMS
But good suggestion with the Make a Wish - will do that.
Appreciate your response.
