How to provision 24 or 48 port switch with one template?
kattmatman
I want to provision both 24 ports and 48 ports C9300 with the same template and have the option to choose if the switch i'm provisioning has 24 or 48 ports in variables.
This doesn't work:
{% if '24' in NUM_OF_PORTS %}
interface range GigabitEthernet1/0/1-24
{% endif %}
{% if '48' in NUM_OF_PORTS %}
interface range GigabitEthernet1/0/1-48
{% endif %}
switchport access vlan
switchport mode access 2
What am I doing wrong?
Thanks in advance!
M02@rt37
Hello @kattmatman
Try this:
{% if NUM_OF_PORTS == '24' %}
{% elif NUM_OF_PORTS == '48' %}
{% endif %}
switchport access vlan 2
Use '==' for exact string comparison
Use 'elif' for mutually exclusive conditions
Best regards
M02@rt37
Hello @kattmatman
Try this:
{% endif %}
Best regards
Thanks alot, works perfectly!
You're so welcome @kattmatman
Best regards
Preston Chilcote
If you want to optimize even more, you can use built in variables to read the product ID to determine if there are 24 ports or 48 ports without having to ask the user to tell you.  This saves a few clicks during provision.  Sorry, I don't have a code snippet easily ready to share, but maybe someone else does.
