How to view lease duration of a Cisco DHCP pool
RBenke
I'm having a devil of a time with this, in spite of numerous Google searches.
I have a Cisco Catalyst switch that is also a DHCP server. I want to view the lease duration of the DHCP pool I created.
I know how to *set* the lease duration, but I cannot for my life figure out how to *view* the lease duration. I know I can see the expiration dates of all active leases, but that's not what I'm looking for. I'm looking for the equivalent of "show me what I typed when I set the lease duration."
Parthiv Shah
If you dont see any output in "show run | sec dhcp" or "show run | incl lease" then it indicates you have selected default lease time. In general default lease time is 86400 seconds which is 1 day.
14 Replies 14
Show dhcp binding
MHM
Thanks, but that's not it. That command shows the expiration dates of active leases, but it does not show what I typed when I set the lease duration. Obviously, I could deduce the duration by doing some math, but surely that's not necessary. What did I type when I set the lease duration?
RBenke
Actually, the command "show dhcp binding" doesn't exist on this switch. I'm typing "show ip dhcp binding".
Show running | in lease
Check this
MHM
I don't get an error with that command, but it produces no output, I'm just returned the command line.
I'm getting the impression that there's just no way to view the lease duration directly, and that one must deduce it from the list of active leases. How odd for such a basic parameter.
You are correct
But what we can do we work with what we have
Did you try
Show run | in dhcp
MHM
Show run | in dhcp
That returns the names of my two DHCP pools, along with any excluded addresses, but not lease durations.
I suppose another way to know the duration is to re-set it. All this started because my server admin asked me the DHCP lease duration on our wireless network and I was confounded that I couldn't find a way to just look it up (I set it years ago). I figured looking it up would be a 15-second task. An hour later I just decided to set a new lease duration and gave him that number.
I do appreciate your effort.
Cisco...really? Come on.
Show run | sec dhcp
MHM
balaji.bandi
what is the device model and what IOS code running to guide to you better here.
Generally most device should work this commands - "show ip dhcp binding" and "show dhcp lease"
BB
It's a Catalyst 9404R running IOS 16.09.02.
"show ip dhcp binding" does not return the least duration, it only returns active bindings, including their expiration datea, from which one must deduce the lease duration. All that is covered in the posts above this one.
"show dhcp lease" does not produce an error but also does not return a value.
show run | sec dhcp
is show all config under the dhcp pool include the lease time
MHM
Since we are not sure what device you using, so we are speculating the commands try and hit, since you mentioned the device and IOS XE code.
suggest to look the dhcp configuration : (depends on what you configured)
Step 16
lease {days [hours [minutes ]] | infinite }
Example:
Device(dhcp-config)# lease 30
(Optional) Specifies the duration of the lease.
  • The default is a one-day lease.
  • The infinite keyword specifies that the duration of the lease is unlimited.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/xe-16-12/dhcp-xe-16-12-book/config-dhcp-server-xe.html
BB
Parthiv Shah
Did you try "show run all | sec dhcp" or "show run all | in lease". If you don't include "all" keyword and you are using the default value of the lease then I don't think it will show up on the output.
