PnP using vlan 3001
rasmus.elmholt
Level 7
Level 7
Hi all,
I have an onboarding template that uses the G0/0 on a 9300 switch to do the initial PnP and get registered on the DNAC, when registered we claim it with some configuration and it is now using a trunk and a management VLAN to register in the inventory.
But if the mangement VLAN is 3001 the switch never created the VLAN and never succeeds in the onboarding.
I have the following template working and the mangement VLAN is 101:
{% include "NDK-Imports/NDK-Ports" %}
!###### Temp debugging #####
event manager applet catchall
event cli pattern ".*" sync no skip no
action 1 syslog msg "$_cli_msg"
logging Buffered 4000000
logging persistent url flash:/PERSISTENTLOGS size 104857600 filesize 5242880
!###### Clock&Timezone&NTP ######
clock timezone CET 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
service timestamps log datetime show-timezone localtime
ntp server 10.10.8.1
!###### Error checks and recovery ######
errdisable recovery cause all
errdisable recovery interval 120
udld aggressive
Spanning-tree loopguard default
!###### Spanning-tree Non-root ######
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 36864
{% set vlans = ['101;admin', '102;elev', '103;print', '104;pub'] %}
{% for vlan in vlans %}
{% set vlanInfo = vlan.split(';') %}
vlan {{ vlanInfo[0] }}
 name {{ vlanInfo[1] }}
{% endfor %}
!###### Access interface #####
!Do not provision until DayN
###### Uplink port ######
default int ra te 1/1/1-4
Interface ra te1/1/1-2
{{ uplink_trunk() }}
!###### Downlink port ######
Interface range te1/1/3-4
{{ downlink_trunk() }}
!###### MGMT Interface ######
interface vlan 1
 shutdown
interface GigabitEthernet0/0
 shutdown
{% set MGMTVLAN = "101" %}
{% set MGMTIPSTRING = "10.254.0.233 255.255.255.0" %}
interface vlan{{ MGMTVLAN }}
 ip address {{ MGMTIPSTRING }}
 no shutdown
ip route 0.0.0.0 0.0.0.0 10.254.0.1
!###### VTP ######
vtp mode transparent
!###### Source interface ######
ip ssh source-interface vlan {{ MGMTVLAN }}
ip tacacs source-interface vlan {{ MGMTVLAN }}
ip radius source-interface vlan {{ MGMTVLAN }}
ip http client source-interface vlan {{ MGMTVLAN }}
ntp source vlan {{ MGMTVLAN }}
!###### DHCP Snooping ######
ip dhcp snooping
ip dhcp snooping vlan 1-4094
!###### AAA ######
aaa new-model
aaa authentication attempts login 3
netconf-yang
!###### Logging #####
logging Buffered notifications
!####### Cleanup from PnP progress
!no pnp profile pnp-zero-touch
 transport https ipv4 10.10.8.10 port 443
The switche PnP's and the configuration is applied and starts to use the uplinks for access to the DNAC and registers with IP 10.254.0.233 as shown in the template.
If I then change the admin VLAN for 3001 the PnP fails every time and the VLANs does not even get created on the switch during PnP.
Changes made for testing:
{% set vlans = ['3001;admin', '102;elev', '103;print', '104;pub'] %}
{% endfor %}
{% set MGMTVLAN = "3001" %}
 no shutdown
!###### VTP ######
All the template generation looks fine in the template CLI:
vlan 3001
 name admin
vlan 102
 name elev
vlan 103
 name print
vlan 104
 name pub
None of the maglev services gives errors, and the network-programmer service seems to be pushing the commands.
Looking at the catchall EEM script on the switch during config push I see:
000148: Sep 21 16:37:48.463: %HA_EM-6-LOG: catchall: vlan 3001
000149: Sep 21 16:37:48.464: %HA_EM-6-LOG: catchall: name admin
000150: Sep 21 16:37:48.464: %HA_EM-6-LOG: catchall: vlan 102
000151: Sep 21 16:37:48.465: %HA_EM-6-LOG: catchall: name elev
000152: Sep 21 16:37:48.466: %HA_EM-6-LOG: catchall: vlan 103
000153: Sep 21 16:37:48.473: %HA_EM-6-LOG: catchall: name print
000154: Sep 21 16:37:48.474: %HA_EM-6-LOG: catchall: vlan 104
000155: Sep 21 16:37:48.475: %HA_EM-6-LOG: catchall: name pub
000235: Sep 21 16:37:48.820: %HA_EM-6-LOG: catchall: interface Vlan1
000236: Sep 21 16:37:48.822: %HA_EM-6-LOG: catchall: shutdown
000237: Sep 21 16:37:48.823: %HA_EM-6-LOG: catchall: interface GigabitEthernet0/0
000238: Sep 21 16:37:48.823: %HA_EM-6-LOG: catchall: shutdown
000239: Sep 21 16:37:53.140: %HA_EM-6-LOG: catchall: interface Vlan3001
000240: Sep 21 16:37:53.140: %HA_EM-6-LOG: catchall: ip address 10.254.0.233 255.255.255.0
000241: Sep 21 16:37:53.141: %HA_EM-6-LOG: catchall: no shutdown
000242: Sep 21 16:37:53.142: %HA_EM-6-LOG: catchall: ip route 0.0.0.0 0.0.0.0 10.254.0.1
000262: Sep 21 18:37:53 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan3001, changed state to down
000263: Sep 21 18:37:54 CEST: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
000264: Sep 21 18:37:55 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
But VLAN 3001 never gets created:
DK-SJ2-TEMP>en
000279: Sep 21 18:39:30 CEST: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: ] [Source: LOCAL] [localport: 0] at 18:39:30 CEST Tue Sep 21 2021
Password:
000280: Sep 21 16:39:33.059: %HA_EM-6-LOG: catchall: enable
DK-SJ2-TEMP#show vlan brie
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
                                                Gi1/0/13, Gi1/0/14, Gi1/0/15
                                                Gi1/0/16, Te1/0/17, Te1/0/18
                                                Te1/0/19, Te1/0/20, Te1/0/21
                                                Te1/0/22, Te1/0/23, Te1/0/24
                                                Te1/1/2, Te1/1/3, Te1/1/4
                                                Ap1/0/1
102  elev                             active
103  print                            active
104  pub                              active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
DK-SJ2-TEMP#
And because the VLAN 3001 never gets created the SVI 3001 never comes up and contacts the DNAC, and the PnP fails.
But if I during PnP manually creates the VLAN I am able to create it and complete the PnP process.
DK-SJ2-TEMP#show ip int brie | inc 3001
Vlan3001               10.254.0.233    YES TFTP   down                  down
DK-SJ2-TEMP#conf
000266: Sep 21 16:47:56.421: %HA_EM-6-LOG: catchall: show ip interface brief t
Enter configuration commands, one per line.  End with CNTL/Z.
DK-SJ2-TEMP(config)#vlan
000267: Sep 21 16:47:58.569: %HA_EM-6-LOG: catchall: configure terminal 3001
DK-SJ2-TEMP(config-vlan)#e
000268: Sep 21 18:48:00 CEST: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name xit
000269: Sep 21 16:48:00.979: %HA_EM-6-LOG: catchall: vlan 3001
000270: Sep 21 16:48:01.890: %HA_EM-6-LOG: catchall: exit end
DK-SJ2-TEMP#
000271: Sep 21 18:48:03 CEST: %SYS-5-CONFIG_I: Configured from console by console
000272: Sep 21 16:48:03.229: %HA_EM-6-LOG: catchall: end
000273: Sep 21 18:48:05 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan3001, changed state to up
Vlan3001               10.254.0.233    YES TFTP   up                    up
DK-SJ2-TEMP#
000274: Sep 21 16:48:12.062: %HA_EM-6-LOG: catchall: show ip interface brief
000275: Sep 21 18:48:12 CEST: %NDBMAN-5-ACTIVE: Switch 1 R0/0: ndbmand: All data providers active.
I have tried this a million times to test, and when I use pnp startup-vlan on the seed switch everything works with VLAN 3001, but for some reason not when I use the OOB mgmt port.
Any comments and feedback is welcome.
The Gi0/0 ports is connected to a switch with the PnP VLAN(101/3001) in access mode, and Te1/1/1 is connected to a switch with the same VLAN tagged.
Preston Chilcote
I tried to reproduce your observation of vlan 3001 not being created.  I used a 9300 running 17.3.1 and a very simple Onboarding template:
vlan 3001
name admin
interface vlan 3001
ip address 10.0.0.1 255.255.255.0
The vlan was placed into vlan database as expected:
9300-pnp#sh vlan brie
1    default                          active    Gi1/0/2, Gi1/0/3, Gi1/0/4
 [snip]
3001 admin                            active
What version are you testing with?
I am using version 17.3.4 and this is only an issue if I start the PNP process on the Gi 0/0 port.
If I onboard it using one of the front facing ports everything works with VLAN 3001 as well.
But using a front facing port for PnP is not an option in my setup as the seed switch will shut down the port with STP-inconsisten as the nativ vlan is not the same on the seed device(vlan 101/3001), and the pnp device(nativ vlan 1).
