push vlans to 9800 wlc with catalyst center
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-09-2024 01:54 AM
Hello there,
I am in the midst of configuring our new 9800 WLC through catalyst center.I have multiple vlans behind a single SSID, and catalyst center wont deploy the vlans if they are not used in a policy or a profil or something.
What would be the best way to get all the vlans on the controller?
Right now I just added them manualy through the cli, but i was wondering if there is a way to push them through catalyst center?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-09-2024 02:15 AM
You should be able to add VLANs under "Design > Network settings > Wireless > Interfaces & VLAN Groups" and they should be provisioned regardless of SSID configuration.
Get in touch: https://torbjorn.dev
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-09-2024 02:30 AM
That is what I thought too, but they dont.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-16-2025 11:49 PM
Hello Janne,
I had the same problem and its part of the Network Profile.
Under Advanced Settings there is the option to add Additional Interfaces
They are pushed to the WLC once you provision it after adding the interfaces.
Cheers,
Harald
