push vlans to 9800 wlc with catalyst center
Janne K.
Hello there,
I am in the midst of configuring our new 9800 WLC through catalyst center.I have multiple vlans behind a single SSID, and catalyst center wont deploy the vlans if they are not used in a policy or a profil or something.
What would be the best way to get all the vlans on the controller?
Right now I just added them manualy through the cli, but i was wondering if there is a way to push them through catalyst center?
Torbjørn
You should be able to add VLANs under "Design > Network settings > Wireless > Interfaces & VLAN Groups" and they should be provisioned regardless of SSID configuration.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Janne K.
That is what I thought too, but they dont.
Harald M
Hello Janne,
I had the same problem and its part of the Network Profile.
Under Advanced Settings there is the option to add Additional Interfaces
They are pushed to the WLC once you provision it after adding the interfaces.
Cheers,
Harald
