Regarding SNMP settings on the Catalyst 1300 switch,
it is different from the CLI commands for other 9000 series
but how do I set it up to send traps to an SNMP server?
I would be grateful if you could show me the specific commands.
This is a basic question, but please let me know.
4 Accepted Solutions
Thank you for your answer.
Is it okay to set only the snmp-server community command?
Thank you in advance.
yes that should work, for i suggest for security reason use SNMPv3
If you using SNMPv2, then use only device required to contact switch to protect SNMP access from other devices.
You can also use ACL as example :
access-list 20 permit  10.10.10.10
snmp-server community  RO 20 (if you need to give only Read Only)
snmp-server community  RW 20 (if you need to give  Read and Write Only - careful with read and write)
BB
Thank you for your kind and easy to understand answer.
M02@rt37
BB
