04-11-2022 07:44 AM
Hi Guys,
I have one Cisco 9200 and smart license is not install on it.
I want to know what will be the impact on device if i doesnt install smart license.
License Usage:
License Entitlement Tag Count Status
network-advantage (C9200L-NW-A-48) 1 IN USE
dna-advantage (C9200L-DNA-A-48) 1 IN USE
04-11-2022 08:18 AM
Operational? none. You are going to receive a lot of logs only. But, if you had some problem and get TAC to look, they might point this.
04-11-2022 08:49 AM
it says already in USE, show License summary or status give you information.
it works as long it was permiitted,
04-11-2022 08:57 AM
Actually currentlly they are in Use but may be in evaluation.
My query is if they got expired after evaluation, is there any impact on network/operation?
04-12-2022 06:01 AM
If they are not register in time, it fall back to basic level that essential License.
04-12-2022 07:25 AM
Afaik that is not correct. If using IOS-XE 17.3.2 and higher, SLUP is in place which does not include any service degradation on switches. Based on the Smart Licensing enable products list*, impact for Catalyst 9200 is "Normal functionality. syslog/alarm notifications."
04-11-2022 11:18 PM - edited 04-11-2022 11:22 PM
Hi Noovi,
check this out please: https://www.cisco.com/c/en/us/products/collateral/software/one-wireless-subscription/nb-06-dna-acces-wl-sw-faq-ctp-en.html
Search for the Question: "Several customers believe that when their subscription expires, a Catalyst 9000 switch will not work. Can you confirm if L2/L3 services will work if the license has expired?"
What features are included within DNA Subscription and which one in Network Essentials/Advantage can be found here:
Network Essentials / Advantage = permanent
DNA Essentials / Advantage = subscription
