Substring a system variable in Jinja template
saschakruszka
Community Member
I'm currently building some DayN Templates to configure non fabric Catalyst 9k2 switches.
Therfore I'm using the system variable __device.hostname to get the name of the current device. Within this name I've got some information I'd like to use, e.g. the hostname contains the device location. So I try to substring this information with the following Jinja code:
{% set device_location = __device.hostname[2:5] %}
Nothing special, i thought but... I realized I was not able to commit the template, because of the following error appears in the Template Editor of the Catalyst Center for the line of code I did provide here.
The error message: "Target unreachable, base expression '. hostname' resolved to null"
Within the simulation this code works as it should do, but this error prevent to commit the template.
If I use the __device.hostname variable without the [2:5] subtring filter, there is no error, but the error persist, when I'm using the string within a non system variable with the substring filter like this:
{% set device_name = __device.hostname %}
{% set device_location = device_name[2:5] %}
Example string/hostname = yyxxx001
Catalyst Center Version 2.3.7.6
Doese anyone know what I'm doing wrong? Anyone experiencing the same behaviour of the Catalyst Center Template Editor?
BR
Sascha
saschakruszka
Community Member
Okay,
This was a variable type issue. After posting this issue I was thinking about it and was trying the following:
{% set device_name = __device.hostname|string %}
Converting __device.hostname to a string with the |string filter works.
Hope this helps somebody else.
BR
Sascha
saschakruszka
Community Member
Okay,
BR
Sascha
