Time frame to install 50 devices in UI for DNAC?
AlexGarten6214
I am awaiting approval on securing an engineer to help with a DNAC install. I am curious on average, how long should that take if you had around 50-80 devices (access points).
Preston Chilcote
I think you're asking 2 different questions:
1) The DNAC appliance install from scratch might take a few minutes to input all the ip and routing information, then a few hours (at least on 1.2. code, not sure about 1.3) to install all the services for the first time)
2) Assuming this isn't a fabric wireless install, the AP deployment should take the same amount of time as it would without DNAC, since they are still getting all their info from WLC.
Preston Chilcote
That is super helpful thank you!
