unable to login on DNAC web interface
ezzaariyouness
Hi everyone ,
I'm unable to login in into dnac web interface , the password correct . I got Invalid Login Credentials.
DNA version: DNAC-SW-2.2.3.5
can anyone help me fix this
If you were able to use the first command, maglev login -k -u admin, and it worked, use a different browser or clear your browser cache as mentioned above, if that does not work you will need to open a case with Cisco TAC.
17 Replies 17
 Can you access it using SSH at least?
it's admin , I can't access with it using SSH , I can only with maglev
Alright, that good.
  And the access is local or do you use tacacs?
Hi Flavio ;
the access is  local .
Access with maglev and type
magctl user password update admin TNT0
Hi Flavio ,
I did update the password but I still not able to login .
Try to use different browser, clean up browser cooks,  password,  etc
Reload the dnac
Hi Flavio ,
Yes did try other browser, the same .
@Flavio Miranda : Thanks a lot for posting! This solution perfectly worked This has unblocked our long awaiting problem.
Working snip:
root@maglev-master-:~# maglev login -k -u admin
[administration] password for 'admin':
ERROR: Invalid username and/or password.
root@maglev-master-:~# magctl rbac external_auth_fallback display
"response": {
"enabled": false
root@maglev-master-:~# magctl user password update admin TNT0
Password:
Confirm password:
Password updated successfully.
After this tried the same password input as in above.
edust
Being unable to open the Web UI to the Cisco DNA Center can be several different problems.
The best thing to do in this instance is to open a TAC case and let TAC look at it. However, you can check, from the CLI:
(This will ask for your "admin" password, if it is successful login to the GUI again. It should work, if the error returns as
ERROR: Invalid username and/or password)
Then run the command:
If this returns as false, this is the issue. If it returns as true, you will need to open a TAC case as there maybe be a context issue or internal certificate problem.
Hi edust ,
I try maglev login -k -u admin it's successful login but formagctl rbac external_auth_fallback display it's  returns as false .
How can I fix this .
Hi edust ;
I did open a case with TAC , they did solve the issue .
Thx
Best regards
Younes
Hi Youness,
Do you know what TAC did? I am running into the same issue.
Regards.
