Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless controller 5520 migrate to 9800 in SDA
gladson14
Hi  Team,
We have 5520 WLC in DNAC and wanted to migrate to 9800 , can anyone suggest the recommended way.
Traditional migration approach i am familiar , not sure how to plan when existing Fabric WLC in DNA
marce1000
 - You may find this discussion informational : https://www.reddit.com/r/Cisco/comments/17a546c/cisco_dna_migrate_fabric_wlc_5520_to_catalyst_9800/
 M.
I just performed the operation described by LordEdam in that reddit thread. It was very easy and went without a hitch.
This is what he posted:
"When you provisioned the 5520, you assigned it to the physical site/building it’s located in then did ā€œmanage primary ap locationsā€ and selected your site (or maybe this was done automatically if you have a single site)
So for the new controller, provision it the same way but click on the ā€œmanaged primary ap locationsā€ and remove every tick box, then click on ā€œmanage secondary ap locationsā€ and tick everything.
Continue with the rest of the provisioning as you did with the 5520, this should setup the controller in N+1 HA mode as the secondary controller with all the same settings. You can then change them over when you’re ready to migrate by re-provisioning and changing the tick boxes for primary / secondary"
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
balaji.bandi
There is no straight forward answer for this.
1. before Migration check the AP are compatible with Cat 9800 and Fabric
2. i would build Cat 9800 with SDA
below guide help you :
https://www.cisco.com/c/dam/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/deploy-guide/cisco-dna-center-sd-access-wl-dg.pdf
3. personally if you are not familiar with sd-access - I suggest to contact partner to help you for the first time, so you can understand better - there are many things need to configure. like DNAC / ISE / WLC  so on (i am thinking you using ISE fo authentication for Wireless and guest access ?)
4. profiles and tags and best practice
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213911-understand-catalyst-9800-wireless-contro.html
Install inline with exiting WLC and test with Cat 9800 and then Migrate area wise to new WLC is best approach (do not leave same area both AP - which give more problematic, when the client roam between old WLC and new WLC)
BB
