07-20-2019 10:14 AM
I am trying to find the download link for the Wireless Sub Package for a Catalyst 9300. Can anyone share the link with me?
thanks
Alex
Solved! Go to Solution.
07-20-2019 10:47 AM
You can find links to the WLC sub-package, along with other SDA related images of the supported platforms, at the SDA compatibility page.
07-20-2019 10:47 AM
07-20-2019 10:54 AM
Cheers, Nathan
07-20-2019 12:27 PM
Hi Nathan,
quick follow up question. I've downloaded the software und uploaded it to DNA Center. Can I push the package from there to the switch or do I have to manually upload the file to the switch?
thanks
Alex
07-22-2019 04:18 PM
Hi Alex,
Yes, DNA Centre will start a workflow to install the embedded WLC package to the C9K switch when you enable the embedded WLC in fabric site provisioning screen.
Jerome
05-24-2021 06:06 AM
Another follow up here, if upgrading the 9300 to a newer IOS release what is the procedure to get the sub-package updated?
06-02-2021 04:10 PM
1-Download de main image and sub-package from Cisco website
2-Import the main image to DNAC
3-Import the sub-package to DNAC
3-Upgrade de switch using DNAC. Both images will be upgraded.
