Cisco DNA login issue
hs2903
CiscHello,
We have a new issue after retrying the upgrade of the DNA center. We can access the web page but not able to login via admin account:
We can only ssh via maglev.
Steps we performed,
  1. Tried to reset the admin account via maglev. It update the password successfully but still can t login. Even local user account were not able to login.
Last login: Mon May 17 11:01:46 2021 from 172.16.66.6
[Mon May 17 11:10:03 UTC] maglev@10.240.19.21 (maglev-master-10-240-29-21) ~
$ magctl user password update admin TNT0
Password:
Confirm password:
Password updated successfully.
[Mon May 17 11:10:26 UTC] maglev@10.240.19.21 (maglev-master-10-240-29-21) ~
  1. Reboot the appliance (warm boot) still same problem.
hs2903
Sorry forgot to mention that even with any local account it s not working.
what is the DNAC version, before the upgrade it was working? and after the upgrade, it is broken?
BB
Questions:
  • What version of the Cisco DNA Center?
  • Do you have "External Authentication" configured for User Access to the UI?
Please gather the following:
$ magctl user display admin
$ magctl user display -t TNT0 admin
$ magctl rbac external_auth_fallback display
If "false", enable fallback and try logging in with local admin user...
"response": {
"enabled": false
$ magctl rbac external_auth_fallback enable
Hi , i also encounter this issue regardless of the user trying to log in.
First time i encountered this, i was able to solve it by clearing cookies, cache, and Offline Website Data.
After that, i was able again to log in.
However, a few days later, i got the same  issue again, and this time, the trick didn't work!
After some trying, i got it working again by opening the page in a Work Container Tab (Firefox)
Hope this helps out.
Cheers
