Provisioning Guest WLAN by DNAC
Maciej Waliszko
I want to provision a new guest WLAN network by using DNAC.
The Guest WLAN is based on ISE sponsored guest portal which does already exists on ISE.
From what I know DNAC can only provision selfregistered or hotspot guest WLAN (and at the same time a new portal is created by DNAC). The question is: how to do that? Any trick? What should I do now?
Do the required tasks on ISE and WLC and then use "learn device config" from WLC? Use temaplates on DNAC? Or what?
Thx,
m.w
5 Replies 5
balaji.bandi
if you looking to create a portal for the user to get authenticate, below resources help you.
here is the good video step by step :
http://www.labminutes.com/rs0129_sda_wireless_guest_1
Cisco document :
https://www.cisco.com/c/dam/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/deploy-guide/cisco-dna-center-sd-access-wl-dg.pdf
BB
That is not what I am looking for. The question was totally different. The portal (sponsored guest) on ISE already exists.
Thank for the clarification,  as suggested you can use re-use exiting portal, instead of creating same process in DNAC.
BB
Dan Rowe
You are not required to use the portal DNA Center allows you to create when adding the guest WLAN from DNAC -> Design -> Network Settings -> Wireless. You can simply update the auth profile to reflect the name of the portal that already exists on ISE.
k.vlachoulis
Is there a guide that describes how we may reuse existing ISE portals on DNA configured guest WLAN?
BR
