Intersight Monitoring tools for UCS..
sachinc01
Beginner
Beginner
Dear Team,
I have 9 Chassis of UCS witch 6 FI  I want to install intersight monitoring tool for UCS But intersight available in OVA & .Bin File
My Current Vm version is 6.0 its need OVF fill to install intersight..
Can some one guide how to install and use intesight & how to convert ova to OVF file for VM(ESXI6.0) installation.
Sachin
didac_f
Beginner
Beginner
Lessons learned after installing Intersight:
  • Have all the prerequisites done DNS A, PTR and CNAME per the installation guide.
  • Convert the OVF to SHA1
  • If you have a proxy, make sure getting involved with your security team and allow all the sites.
  • Have your smart licensing on check.
  • See the installation guide on this link: https://www.cisco.com/c/en/us/td/docs/unified_computing/Intersight/b_Cisco_Intersight_Appliance_Getting_Started_Guide.pdf
  • As far as UCS make sure at least that you are running the version 3.2.x at least, you will have to update the connector (no reboot required) If you have UCS 4.0.x, you are in luck, no need.
  • Any system that needs integration with Intersight, go to devices and register it using the IP or FQDN and credentials.
jzitcovi
Sahsin,
The Intersight OVA is for an on site deployment of Intersight.
Is there a requirement to run Intersight on prem?
If not I recommend to use https://intersight.com
https://www.intersight.com/help/getting_started#cisco_intersight_setup_and_device_claim
Recognize Your Peers
