sub interface connectivity
SanSat89
How do i simulate connectivity between sub interfaces in iosv router in cml? when i try creating links it only shows me the interface to simulate connectivity rather than the sub interface.
2 Accepted Solutions
Hi SandipanSatapathy70156,
sub-interfaces are logical interfaces, which are part of, or members of a physical interface. In CML you connect the physical interfaces with each other. Sub-interfaces are matter of configuration and not available in the "physical" world. You can imagine a physical link as a L1 link and logical ones as L2 links.
What are you trying to accomplish or model?
Best Regards,
Shin
That is a Physical connection, you need to manually create a sub-interface and tag it if required based on the VLAN.
example :
config t
interface gig0/0.1
dot1 vlan 100
ip address x.x.x.x
BB
6 Replies 6
balaji.bandi
it should be, can you post-show a version of the image you use?
you mean sub interface Layer 2 or Layer 3 ?
BB
Martin L
you need to manually create sub-interface(s) on routers. by default, there are no sub-interfaces on any routers anywhere
Regards, ML
**Please Rate All Helpful Responses **.
SanSat89
Hi Balaji/Martin,
Thanks for your response!
The issue isnt creating sub interfaces on the router. I am able to do that in config. Its when i create a link between two routers it does not show me the option to create link between sub interfaces of two routers. I have attached a screenshot for your reference.
Best Regards,
Shin
example :
config t
interface gig0/0.1
dot1 vlan 100
ip address x.x.x.x
BB
a-gould
In this video I show how to accomplish vlan tagging in CML (Cisco Modeling Labs) using IOSv and CSR1000v (EFP, Service Instance)
https://youtu.be/_7h46lhCv6U
