VXLAN vPC behaviour (CML)
19RedWolf81
Hi All,
I'm getting some odd behaviour in my VXLAN Lab within CML. This only happens when I enable the vPC feature on the LEAF switch (no other vPC configuration has been applied, only the feature has been enabled).
  • Client3 on the LEAF switch with the vPC feature enabled can't resolve any other clients on another LEAF switch.
  • Client1 which is on a standalone LEAF switch can resolve Client3 and successfully ping Client3.
  • Now Client1 has pinged Client3, Client3 can now ping Client1.
This seems to be a problem with BUM traffic from the LEAF switch not being forwarded when the vPC feature is enabled. If I disable the vPC feature the behaviour stops and the switch forwards the BUM traffic normally.
The Nexus Image Version: 10.5.1.F, CML 2.8.1
Has anybody else come across this behaviour at all.
Many Thanks
Scott
19RedWolf81
Well after importing the following NX-OS image 10.3.5.M into CML. My lab is now working as expected.
Note: I have also found that using a second loopback interface for the NVE interface anycast address, does not work in CML.
5 Replies 5
M02@rt37
Hello @19RedWolf81
Interesting point.
If you go further with vPC config (vpc domain), you have the same symptom ?
With vpc feature enabled, EVPN may suppress or modify BUM handling, especially if peer-gateway is expected but not configured.
Best regards
balaji.bandi
When I was testing VXLAN, I used vPC between Leaf switches, and it worked as expected (as  I remember, and let me check my notes).
As i see this may be virtual environment issue, what is the reason of enabling vpc feature if not used ?
BB
19RedWolf81
M02@rt37 Yes, I get the same behaviour with full vPC configuration in place. I think this is an issue in the 10.5.1 NX-OS image as I have seen several labs on the internet using VXLAN with vPC but using older NX-OS images. I might try importing an older image into CML and giving it another go.
@balaji.bandi I'm building labs to get a better understanding of VXLAN concepts/design and troubleshooting. I find reading information can only take you so far, I find nothing better than getting on CLI and configuring it.
19RedWolf81
Thanks a lot for you feedback @19RedWolf81
Best regards
